Exhaust Manifold to Y-pipe nuts
Old Aug 27, 2021 | 07:43 AM
yachtmanbuttson's Avatar
Default Exhaust Manifold to Y-pipe nuts
Wondering what the general consensus is regarding the best nut to use - copper, brass, SS, etc. I'm having trouble where the stock nuts I'm using keep loosening up. And I've tried varies lock washers and thread locker liquids to no avail. Any ideas from the group?
Old Aug 27, 2021 | 07:57 AM
Doug's Avatar
Brass.
See if you can still order genuine Jag nuts. They're brass with a locking insert of some kind. That's my experience, at least.
Old Aug 27, 2021 | 12:46 PM
JagCad's Avatar
Not on the oroginal jaguar manifold, but on the Lt1 manifolds. Brass nuts, star washers and antiseize!!! Much past exerience with busted manifold nuts and studs!!!!
Carl
Old Sep 1, 2021 | 07:59 AM
I decided my best option might be brass jam nuts:
Old Sep 1, 2021 | 10:10 AM
Jose's Avatar
the problem might not be the nuts but the bolts.
Go to an ACE Hardware and get new stainless steel bolts, flat and lock washers, and nuts
that's how I did my down pipe to Y pipe conjection and it has never come loose.
bolt with flat washer through flanges, flat washer, lock washer, and nut.
Old Sep 1, 2021 | 10:28 AM
Jose - Great Idea! However.... No way am I going to try and get the old studs out! I've had bad experience with a previous cast iron exhaust manifold with the manifold cracking and breaking a corner off trying to remove the stud. Yes, I used heat, brought it to a machine shop - not going to do that again. So, I'm stuck using the old studs. I really think the jam nut idea is going to work. And the brass nuts shouldn't fuse (rust) to the stud making taking it apart in the future risky. But... always open to thoughts from you and the Forum.
Bill
brinny
Nov 15, 2020 01:41 AM
Pirk
Aug 17, 2020 06:22 PM
ben4633
33
Nov 18, 2017 11:16 AM
iramphal
Sep 22, 2017 05:52 AM
Mundrwood
Oct 18, 2015 02:42 PM
