Exhaust question
Old Jun 10, 2021 | 12:47 PM
ruffindustries's Avatar
Default Exhaust question
Hey guys, quick question. I currently have no exhaust from the mufflers back. I just ordered some over axle pipes from SNG and they wont be here for a couple weeks. I don't want to get a crazy amount of money tied up into this because ill be doing an engine swap within a couple years and it will be getting replaced with a larger diameter pipe. Are there any recommendations on a more economical rear silencer/resonator that I can purchase to get me by? Also does anyone have any clue what the mating diameter is on those axle pipes? 1.75, 2"? Thanks
Old Jun 13, 2021 | 09:13 PM
icsamerica's Avatar
I'd try this.
https://www.ebay.ca/itm/162664975714...kAAOSwQmJc0yLi
Old Jun 13, 2021 | 11:06 PM
Doug's Avatar
This might interest you:
https://www.jaguarforums.com/forum/x...6-12-a-146097/
I recall the pipe is 1.875" but I'm a bit foggy on that
Old Oct 6, 2021 | 10:20 PM
Robert S's Avatar
My exhaust system was a bit of a hack job and one of the welds failed, causing it to drop a pipe on the ground from the joint behind the rear cat on the left side. I rented a tailpipe cutter from the local parts store and deleted the entire system from the cats back. That was about a year ago and I haven't gotten around to building a new exhaust system. I haven't been pulled over yet.
Old Oct 7, 2021 | 01:59 PM
JagCad's Avatar
Three more ideas:
1. Visit the local muffler shop and let them build a muffler back system omitting the rear resonators. Pass the pipes under the IRS cage for simplicity
2 Replace a stock. use with the :Lump. I did, it worked out perfectly.
3. I forgot it!!
Carl
Treozen
Mar 22, 2019 10:36 PM
John Gloyd
Mar 3, 2016 11:42 AM
JagYour
Aug 28, 2011 12:37 AM
rosemont83
Sep 9, 2008 03:20 AM
