Finally no more noise from the front suspension
Old Mar 9, 2018 | 12:35 PM
Dutch-Cat's Avatar
Default Finally no more noise from the front suspension
Ever since I bought the V12, I have been annoyed by a disturbing knocking sound from the front suspension when driving through pot holes or on uneven roads...
Finally got so annoyed that I ordered new bushes from SNG:
https://www.sngbarratt.com/nl/#!/Ned...9-ae2450d059fc
Now this truly IS the sound of silence.....magnificent...
Old Mar 9, 2018 | 02:54 PM
Sort of makes you wonder why you waited so long, doesn't it.
I know that feeling.
Old Mar 12, 2018 | 06:22 AM
Dutch-Cat's Avatar
How right you are.....always thought it would be a sh.tload of work ("normal" cars have bearings there etc...), but it turned out to be a 10 minute job with the air filters removed.
Old Mar 12, 2018 | 06:29 AM
Well done.
As I say many times, simple cars these V12's.
Old Mar 12, 2018 | 01:46 PM
Yellow series3's Avatar
Really interested in this repair as I too, have clunking. I can't tell from the part page what it is or where it goes. Can you provide more detail and maybe some photos. Thanks for your help.
Jeff.
Old Mar 14, 2018 | 04:18 AM
Dutch-Cat's Avatar
It's a fairly easy procedure really:
https://cdn.sngbarratt.com/illustrations/jj001821.svg
V12:
1. remove the air filter housing covers and the filters
2. remove the upper nut on the top of the dampers (no. 2) (counter the lower nut while doing so, both 14mm spanner)
3. remove the lower nut on the top of the damper (no. 3) (counter the damper with a 7mm spanner, soak liberally in castor oil before doing this)
4. remove the washer (no.4), the old bush (no. 5) (or what's left of it) and the bush cup (no. 6)
5. clean or replace the cup, the bush and the washer and assemble in reverse order...
VERY IMPORTANT!
DO THIS WITH THE WHEELS ON THE GROUND!
Otherwise, the damper will "fall" through the wheel well.....
Old Mar 14, 2018 | 10:49 PM
Hi Dutch-cat. Thanks for the information. When I saw your detailed instructions and saw the drawing, I had to laugh. You see, I have done that many times only in the middle of America we call it "replacing the rubber bushing on the top of the shock absorber". I'll order the parts and replace them and see if that helps my clunking situation. Thanks for helping me understand. I just wasn't familiar with the word "bush" in that context - we use "bushing" over here.
Old Mar 15, 2018 | 07:28 AM
Fraser Mitchell's Avatar
V12:
VERY IMPORTANT!
Hang on a minute ! What about the bush on the underside ? These sack-out too.
Old Mar 16, 2018 | 05:10 AM
Dutch-Cat's Avatar
Quite right, but they aren't listed in the Barratt's catalogue and weren't defective on my car.
ramandanu
Jul 9, 2015 01:22 PM
EZDriver
Jul 23, 2011 04:48 PM
jagxkrtoofast
Mar 16, 2010 03:44 PM
WldCat
Sep 8, 2007 11:38 AM
reyesnation
Sep 12, 2006 09:10 PM
