front suspension help
Old Apr 20, 2015 | 03:09 PM
sunchip's Avatar
Default front suspension help
I cant seem to get the lower control arm off... I dont want to start hammering it if i dont have to... any help please
Old Apr 20, 2015 | 03:23 PM
Jose's Avatar
hi,
are you following the factory Service Manual steps??
you can download it free in this forum, go to HOW TOS section.
Old Apr 20, 2015 | 03:31 PM
Doug's Avatar
Is the long fulcrum bolt out yet? Or is that where you're stuck?
Old Apr 20, 2015 | 04:56 PM
The factory ROM says to "drift the bolt." That means to use a brass drift (long beat-on-it rod made of BRASS, pictured below) and beat the **** out of it until it's free.
We've just done this. One side came easily because it was bathed in steering oil, the other side took a Lot of effort.
Old Apr 20, 2015 | 08:39 PM
icsamerica's Avatar
I've never had one come out easy.
Heat, sledge hammer is what it takes. Sometime you mushroom the threads and sometime you get lucky and don't.
Old Apr 21, 2015 | 02:05 AM
Nookieman's Avatar
That is a lot of surface area to get loose. Is it lubed on reassembly?
Old Apr 21, 2015 | 02:25 AM
o1xjr's Avatar
Mine were mushroomed from the beating they took to remove them. I repaired the threads but wasn't happy with them so removed them again when the new ones arrived.
I had a new pair made up locally for $40 each.
Old Apr 23, 2015 | 08:12 AM
sunchip's Avatar
one came out with some heat and a couple hits, other one... not so much... lots of heat and took about a 1/4 inch off the threads... found some replacements for 70 bucks each sent everything off to sand blasting and powder coating
Mugatu
22
Jun 23, 2020 01:50 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
wardo5757
Sep 11, 2015 11:31 AM
02jagstype
Sep 4, 2015 08:20 PM
arnoldmilk
Sep 3, 2015 07:42 PM
