Fuel gauge stopped working
Old Jun 12, 2016 | 07:17 AM
jjd's Avatar
jjd
Default Fuel gauge stopped working
Series 3 fuel gauge reading empty (common jaguar problem I know!) But tank is at least 3/4 full. Basically can gauge be removed from dash easily to check connections and where is tank sender unit so I can check both. Then I can isolate the issue hopefully. Cheers JJ.
Old Jun 12, 2016 | 08:27 AM
Doug's Avatar
Yes the gauge can be removed. Most remove the speedo (or tach) first and gain access that way.
There is a sending unit in each tank, accessed by removing the tail light
I suggest testing the circuit by grounding the sending unit wire for whichever side is in question. Remove tail light, locate the light green sending unit wire, use a jumper wire to ground/earth the light green wire, turn key 'on'.
The gauge should rise to 'full'. If it does, everything in the circuit is OK and the sending unit must be faulty.
If it doesn't move to 'full' then you can begin checking wires, connections, etc
Old Jun 12, 2016 | 08:33 AM
JagCad's Avatar
JJ:
Lucky us. There are two tanks. Each has it's own sender. Access is through the
tail lights. Fiddly, but doable.
The pump is in the boot, just behind the spare tire. The tank selector valve is there as well.
The tank selection switch is on the fascia. Left in, right out, I think.
That is where I would start my diagnosis. Select tanks. any difference.
Oh, just quizzical. Perhaps the tank is empty!!! Just read an article in "Hot Rod
on fuel gauges. Truck quit running. Guage indicated fuel in the tank. Old fashioned
method. Yard stick belied that!! No gas...
If indeed, your tank is half full and he guage reads empty, the float may have sunk!!
The sensor is a variable rheostat operated by an arm with a float. Similar in a way to a toilet tank valve.
Check and report back. I and/or others will pitch in.
Carl
Old Jun 12, 2016 | 08:45 AM
JagCad's Avatar
Yup, Doug posted while I was typing. My slow typing delayed by sips of morning coffee.
He's probably on second cup or more...
Carl
Old Jun 12, 2016 | 03:21 PM
Jose's Avatar
he even typed detailed steps today! haa
Old Jun 13, 2016 | 08:43 AM
jjd's Avatar
jjd
Excellent folks I'll try sorting it now. :icon_imnotwor thy:
Old Jun 13, 2016 | 10:20 AM
jjd's Avatar
jjd
Yep, earthed green wire and gauge worked. Removed sender and float. Only reads full or empty, nothing in between. Swapped it out with other tank sender unit as I never use the other tank and all seems Tickety boo! Many thanks everybody. JJ.
gotwish
F-Pace (X761) / C-X17
21
Dec 14, 2020 08:49 PM
klfong
Apr 7, 2016 05:51 PM
Ron Ho
Mar 31, 2016 11:41 AM
springer
Mar 28, 2016 01:37 PM
DEklof
Mar 28, 2016 12:07 PM
