Fuel Tank Button Sticking...Help please!
Old Jan 7, 2015 | 03:08 PM
SouthernGal's Avatar
Default Fuel Tank Button Sticking...Help please!
Hello fellow Jag lovers!
Boy, it's been awhile. I haven't been on since Oct 12th!! I get busy when the holidays near with my business, and can't catch a breath until after the New Year. Anyhow, my fuel tank button sticks in and remains on the left tank unless I get needlenose and gently work it out. I've knicked the button, so I stopped doing it and just fill up every 10 gallons. Any help on how to lubricate or fix this some how??
Thanks so much!!
Old Jan 7, 2015 | 03:44 PM
Saemetric's Avatar
I'd just replace it. Not that difficult if you like to tinker. Will need to remove the switch panel to replace it. Could try squirting a little wd40 when switch is in out position along sides of movable portion and see what happens.
Old Jan 7, 2015 | 04:12 PM
Jose's Avatar
yes, spray wd40 thru all 4 sides and the heck with it, at this point you have nothing to lose by ruining it completely if you ruin it. Use the little red tube that comes with the can to inject the fluid.
if nothing improves, contact David at Everyday XJ and tell him to send you a replacement switch. He has them.
in theory, you can pull the switch out without having to dismantle the panel; The switch has two "spring" clips, one on top, one at the bottom, nothing on either side.
but it takes a lot of strength and leverage to pull it, and if you use large pliers, you end up crushing the plastic switch into pieces, bad idea.
here's my idea: Put some heavy duty winter gloves, find a .009 or .010 gauge guitar string at your local music store; Buy Safety Goggles at your local autoparts store; When working in a car, you need to protect your eyes.
Wrap the ends of the string around both gloved hands, until you have about 3 inches left between both hands; Now slide the string under the bottom edge of the switch and start pulling it, easy does it. See if it moves out. Try it on the top edge, one side is always the "weak side". If no cigar, then I'm afraid you will have to pull the panel and then work the switch out from behind, and that is not a very easy or fast job.
The picture below shows the two spring clips that need to be compressed to allow the switch to come out.
Attached Thumbnails Fuel Tank Button Sticking...Help please!-switch.jpg   Fuel Tank Button Sticking...Help please!-string.jpg
Old Jan 16, 2015 | 04:44 PM
davidboger's Avatar
Here's a step by step for the fuel switch replacement...
Fuel Switch Replacement
If you find that it is sticking, and need a reasonably priced replacement, I'll be glad to help..
David
Everyday XJ
Old Jan 16, 2015 | 05:59 PM
Jose's Avatar
excellent David,
please make me one of those notched tools, let me know how much.
Jim, this article should go in the HOW TO section.
dsnyder586
Dec 29, 2024 07:39 PM
Razor
Aug 28, 2019 08:34 PM
Kodiak
F-Pace (X761) / C-X17
28
Jul 24, 2016 02:31 PM
hen555
Sep 7, 2015 11:13 PM
deanh
Sep 6, 2015 08:20 PM
