Fuse #3 Blowing
Old Aug 30, 2024 | 01:50 PM
Childeric12's Avatar
Default Fuse #3 Blowing
Hi Everyone,
In my 1983 XJ6 Series 3, US spec. LHD, fuse #3 blew on me yesterday. Every time I try to replace it, it blows right away. So, clearly some positive wire is pinched somewhere coming off of that fuse. I was just wondering if anyone knows the routing of wires coming off of that fuse? Hopefully, someone knows of a common "pinch point" that can help point me in the right direction. I pulled both of the inline fuses for the radio, and tried to reinstall fuse 3 and it blew right away. Given that, it is not the radio or its wiring but rather the antenna, or courtesy lights. If it is the radio wiring, it would be somewhere before that little 5 amp and 1 amp inline fuse. Any ideas? I have had some trouble with the switch in the drivers door jamb not turning the lights on when I open the door. I bought a new one from SNG and was going to install it so, maybe that wire is loose? Thanks in advance!!
Old Aug 30, 2024 | 05:54 PM
Doug's Avatar
Unplug the antenna relay (green, in the trunk near antenna motor) and see if anything changes
Old Aug 31, 2024 | 06:06 PM
Hey Doug, I was hoping you would chime in! I tried unplugging it, but no change. I also removed the scuff plates in the door jambs and replaced the two courtesy light switches in the jambs that didn't work well. Still no change.
Old Aug 31, 2024 | 06:53 PM
I have a theory. I installed some opera lights in the rear. The car didn't originally come with them. I used the factory wiring in the corner of the rear door jambs. I wonder if the wire is coming loose and then grounding somewhere.....
Old Sep 1, 2024 | 09:11 PM
So far, no luck. I put in new courtesy lights in the B pillar. Will check those next.
Old Sep 2, 2024 | 02:53 PM
Turns out the connection in the courtesy lights in the B pillar came loose. FIXED!!
Albertajag
May 28, 2024 04:16 PM
Omid
Jan 13, 2023 10:27 AM
EZDriver
May 15, 2020 09:13 PM
knewt
Jan 20, 2020 05:00 PM
SamtheSham
May 20, 2019 08:07 AM
