How to adjust volt guage
Old Jun 18, 2019 | 12:25 PM
Yellow series3's Avatar
Default How to adjust volt guage
When I bought my 87 and started the long drive home I noticed the volt meter was showing low voltage. I stopped at Lowe's and bought a nice digital multimeter and confirmed voltage was correct with engine off and also with engine running. Took the dashboard out yesterday for my new woodwork and tested the volt meter. You can see in the photo below the difference between XJ6 guage reading and the true voltage (at the battery with engine off). Also, the guage climbs up to this reading very slowly. Like maybe 60 seconds with a lot of tapping on the glass.
The next photo shows the back with what looks like a little adjusting shaft. It doesn't seem to turn. Anyone know if that is supposed to be an adjustment knob? Any other suggestions? Thanks for your help.
Old Jun 18, 2019 | 01:33 PM
Second photo didn't seem to post. Here it is
Old Jun 18, 2019 | 01:37 PM
Jose's Avatar
those gauges are always like that, curiously, in my '65 S type they are a lot more accurate.
I guess what you mean by "adjusting" is to calibrate?
Old Jun 18, 2019 | 01:55 PM
sanchez's Avatar
If I am not mistaken, that adjustment(if it is) will allow you to zero the volt gauge.
My car suffers with the same issue, but once accelerate or I am driving the car the gauge reads correctly. I will just live with it until somebody comes up with a fix.
Old Jun 18, 2019 | 08:09 PM
Doug's Avatar
That IS the calibration adjustment, yes. No idea why it won't turn. Try harder; if you break it, replacements are cheap and easy to come by
As for the lazy operation, well, every Ser III I've owned or driven had a lazy voltmeter...both Lucas and Veglia gauges. Weird.
Old Jun 19, 2019 | 08:20 AM
Doug, you are a genius. That little shaft on the back of the volt guage adjusted the volt reading just like you said. For others that want to adjust (calibrate) theirs, counter-clockwise raises the volt reading and clockwise lowers the reading. And it is very sensitive, a slight twist changes the reading by a couple volts.
Jeff
Old Jun 19, 2019 | 09:38 AM
Hmm.
I've never had trouble with Nix's volt meter, if anything it reads a couple volts high which given her age surprised me a little.. However, I've never had Any electrical trouble with that car.
It was obvious when I got into the dash and under the console that a Lot of work had been done, but if the snake doesn't bite you, you never know it was there. I'm thinking the PO, at the time of Restoversion also had all the electrics fixed.
That almost makes up for all the things he Lied about. Almost.
Old Jun 19, 2019 | 10:18 AM
Jose's Avatar
Elinor, that is why one never buys a car sight unseen, most car sellers lie, misrepresent, distort. There are always exceptions.
When I decided to buy a classic S type, I flew to Oakland CA. to see it in person. I just did not believe the pictures I was sent. Turned out the owner was a famous shipping broker from World War 2 fame, with posters of himself and President Eisenhower in his office, for having helped in the war effort in the Pacific. I had to eat my doubts for this man was an honest war hero in his 80's. The car was pristine as he described it and it brought me back to Tennessee 2,900 miles away. Rest in Peace Ted Rausch.
Old Oct 19, 2023 | 09:36 AM
Noah's Avatar
I'm reviving this helpful thread regarding Voltmeters/battery gauge to ask a couple of questions. I know the voltmeters are notoriously "lazy" and take some time to register a reading. But my '87 has been never registered accurately, always showing about 11 volts while idling or driving although a voltage meter in the cigar lighter shows 13.5-14V and when I check directly at the battery while idling I get a reading over 13V. I replaced the alternator and the wiring from it to the starter and to the firewall post in the last year. I'm in the process of swapping in new bulbs for the all the gauges and decided to finally address the faulty voltmeter.
When bench testing it with a spare battery, is it as simple as attaching pos and neg on the battery to the + and ground on the gauge? Because I'm not getting a reading at all. I also tried grounding the case of the gauge but still no reading. The needle is not bent, it just doesn't move. So maybe I fried it when I took it out or when trying to test it.
Old Oct 19, 2023 | 09:54 AM
Doug's Avatar
Yes
My experience is these volt meters need to see 13+ volts before they respond at all. Your spare battery, even if fully charged, is probably about 12.5-12.7 volts
Old Oct 19, 2023 | 10:24 AM
Noah's Avatar
Thank you Doug, that makes sense. My spare battery was reading about 12.5 when I was trying to test the gauge. I've cleaned the connections and I'll try testing it in the car again with engine running then try to calibrate it.
Old Oct 19, 2023 | 11:38 AM
sov211's Avatar
Doug…is there not a fine “exciter” wire that sometimes comes loose from the alternator, the purpose which is to get that gauge moving more quickly? Or am I inventing this?
Old Oct 19, 2023 | 12:20 PM
Jose's Avatar
mine is also lazy registering but if I tap on the glass the needle moves to the 13 volt mark.
I remember this started happening when I changed the alternator from the original Lucas to John's Cars' GMAlt kit. I have never been satisfied with that GM alternator. I just didn't want to repeat that job but maybe one day I will get fed up enough to install the V12 alternator.
Old Oct 19, 2023 | 12:57 PM
Doug's Avatar
The exciter wires kick starts, so to speak, the alternator. When your ignition light extinguishes the alternator is charging.
The exciter wire has no direct bearing on the voltmeter itself
XK8Forme
Oct 5, 2024 11:13 AM
Bernhard
Dec 20, 2022 01:50 PM
adenshillito
Feb 21, 2017 09:35 AM
vettegood
May 18, 2012 06:58 AM
