Intermitant Heavy Steering
Old Nov 7, 2020 | 02:01 AM
Daf11e's Avatar
Clarke I read somewhere where the collet number 16 is sometimes broken.....just a thought.
Old Nov 7, 2020 | 02:29 AM
o1xjr's Avatar
The collet is there and looks good. Everything looks ok.
I drive by Aaron Goldman’s “Classic & Prestige” jag Indy shop most days so I will drop in this week and pick his brain.
Old Nov 7, 2020 | 02:30 AM
Daf11e's Avatar
Just a thought....it’s not worn down.
Old Nov 7, 2020 | 02:43 AM
Thought also.
Those 2 collets are the right way round???, I got then wrong on the old S Type, took ages to see MY mistake.
Old Nov 7, 2020 | 04:34 AM
o1xjr's Avatar
Originally Posted by Grant Francis
Thought also.
tried both ways, one way nut and lock nut fit on steering wheel. Other way you can do nut up tight but no room for lock nut on thread. So I assume It is right.
But you know what they say about assume. Makes an “***” out of “u” & “me”.
Old Nov 7, 2020 | 06:13 AM
Just mentioned this to Greg, among other things.
He remembers seeing a video on that, and that knurled wheel thingy #13, clamps on #8 to lock the shaft.
The guy removed the wheel, then that circlip and found one of the collets inside that part that were out of whack. Not the wheel collets, there are more inside that #8. He said it was a long while ago when he saw it, but the guy had it sorted in minutes.
Old Nov 7, 2020 | 01:33 PM
o1xjr's Avatar
Thanks Grant, I will check that out later today.
Old Nov 7, 2020 | 01:35 PM
  #28
JagCad's Avatar
"COLLAPSED" Understatement of the year!!!! But it sure is dispositive!!!
DONE AND SOLVED. Two of my favorite words.
So, the Assume axiom is alive and well down under!!!
On to the next issue? or fun time!!!
Carl
Old Nov 8, 2020 | 01:41 AM
Greg in France's Avatar
The programme was Wheeler Dealers doing up a Jaguar XJ Series II Coupe. As Grant sid, it was pretty obvious when he got in there how the two parts locked together. I think on one the tapered bit was worn and it was a simple matter to get or fabricate another and job done.
Old Nov 8, 2020 | 01:47 AM
  #30
o1xjr's Avatar
Thanks Greg, had a look today. My thinking is the taper in the top of the new steering column looks a fair bit more worn than the taper in the old column. If I put the lock nut in the old column it locks up.
Old Nov 8, 2020 | 02:05 AM
  #31
o1xjr's Avatar
Carl
I have done a bodgy job to get it locking up for now. But Miss Fireball is resuming daily driver duties tomorrow. 155 km a day to get to work and back. I have been riding most days the last 5 weeks (and taking jeep 1 or 2 days a week)but giving the old girl a good run this week to make sure problem is solved.
Moved up from the shed to the garage, expecting a few wet days so had to get her into the house so no chance of getting stuck in a wet back yard.
New Maxxis tyres on the S3 rims. Will be nice to see how they feel, only did 3 km on them since fitting.
Old Nov 8, 2020 | 11:32 PM
  #32
Daf11e's Avatar
This is the part from wheeler dealers I think that Greg is talking about.....worn down.
The video is called Fixing the locking mechanism on a jaguar XJC/ wheeler dealers......just google it.
Leon57
Jul 17, 2020 06:45 AM
INDYJAG-84
Dec 14, 2018 06:01 PM
leo_denmark
Apr 2, 2018 03:08 PM
Jonathan-W
Dec 1, 2014 09:43 AM
Rique
Oct 2, 2009 03:19 PM
