Little fuel tank screen socks
Old Jul 10, 2024 | 08:39 PM
AndyZ414's Avatar
Default Little fuel tank screen socks
Hi,
1984 XJ6, refurbing some used tanks to replace the rusty ones that are on the car.
I put some vinegar in there and swooshed it around and out came this little screen filter.
Do I need it? And where does it go? I can’t find nothing online.
thx! Andy
Old Jul 12, 2024 | 01:06 AM
Scd's Avatar
Scd
Hi, are the ‘new’ tanks from a fuel injected car? If so then its a foreign body, however it does look a bit similar to the filters fitted to the immersed pumps installed in some carb models , in which case the tanks will need some modification for a return feed if fitted to a fuel injected car. Regards Simon
Old Jul 12, 2024 | 01:51 AM
con244's Avatar
Andy the filters usually slide onto the outlet pipe on the inside of the tank but usually there is a plastic top which is a tight fit and keeps them on. The plastic bit may still be on your outlet pipes. When I cleaned my tanks they were floating around as well. I removed them and fitted new inline filters between the tank and the pump to help keep the fuel clean and to also allow for regular easy cleaning of the filters. Unfortunately my car is at the mechanics at present so cant post pictures but I am sure there are plenty of others in the archives.
Con
Old Jul 12, 2024 | 08:37 AM
yachtmanbuttson's Avatar
My 2-cents worth. It's MUCH easier to clean/replace EXTERNAL filters rather than internal filters. I opted to only use external.
Old Jul 12, 2024 | 12:31 PM
AndyZ414's Avatar
Hi all,
Yes I agree and thx for recommending that.
i will get 2 new inline filters in the trunk for both sides.
Fuel will be clean and rust free.
thx again!
Jim Kristeff
Nov 18, 2023 10:35 PM
AnD3rew
Sep 28, 2019 10:30 PM
rwgaddy
Aug 26, 2017 03:16 PM
87XJSCoupe
Nov 28, 2014 07:44 PM
Gordo
Jul 28, 2009 07:59 PM
