Lug nut compatibility
Old Jun 16, 2012 | 11:22 AM
e21pilot's Avatar
Default Lug nut compatibility
I am going to go replace the old 15" wire wheels (broken spokes) on my 87' Ser III with 16" wheels from an XJ40. The new wheels are aluminum and I need to get some matching lug nuts for them.
Wondering if the stock XJ40 lug nuts will fit my Series III since they both came with aluminum wheels from the factory?
Old Jun 16, 2012 | 08:29 PM
doghead08's Avatar
are you lookin to get rid of any wire wheels
Old Jun 17, 2012 | 02:06 AM
Fraser Mitchell's Avatar
AFAIK the stud (lug) diameter and thread size is the same. However, the nut shape can vary depending on the wheel. My old 1980 Series 3 nuts for steel wheels were completely different to those for the later 'pepper-pot' alloy wheels, but both the same thread.
Old Jun 17, 2012 | 02:48 PM
e21pilot's Avatar
Are the pepper wheel lugs flat or are they tapered? It's good to know the thread sizes are all the same.
re: the old wires, I was going to toss them because one has broken spokes and the front two are rusted from road salt. I looked into salvaging them but refinishing wasn't worth the expense.
Old Jun 18, 2012 | 06:01 AM
doghead08's Avatar
i just need one wheel...do you have 1 wheel still indecent shape? can you send a pic
Old Jun 19, 2012 | 10:56 AM
e21pilot's Avatar
doghead08: I think the rear wheels are in the best shape but they still have a little surface rust on them. I can send a pic if you send me an email. Are you local to Northern California?
Old Jun 19, 2012 | 04:54 PM
As I recall, the nuts have a taper on then where they butt up to the wheel. Note when you fit alloy wheels, that you need to grease the hub face where the wheel sits, because the wheel can become "glued" to the hub through corrosion iron-aluminium
Old Jun 19, 2012 | 08:29 PM
e21pilot's Avatar
I think you are correct about the taper. I ended up getting a set of used lug nuts from a 1994 XJ40 -- new ones from the dealer are way expensive!. That should work well since the threads are the same for those years and the nuts are guaranteed to match the wheels.
Now I just need a few missing center caps and I'll be set. Too bad those center caps are expensive also.
Old Jun 20, 2012 | 06:04 AM
doghead08's Avatar
im in jersey
phsbb08@comcast.net
Poet
Feb 7, 2025 02:18 PM
Johnken
Apr 8, 2018 10:21 AM
MrWhite
33
Oct 22, 2015 10:29 AM
Wayne Enticott
Sep 29, 2015 08:55 AM
