Nardi Steering wheel installed
Old Feb 26, 2019 | 12:41 PM
iramphal's Avatar
Smile Nardi Steering wheel installed
Well, I finally received the new Nardi steering wheel and hub adapter. I'm thrilled!
Installed it today and everything fits perfectly and everything works. The wheel sits maybe 1/4" closer to the driver (with telescopic adjustment at full retreat), but that does not seem to be an issue. The original wheel was already a bit too far forward from the turn stalks anyway. The fact that the Nardi wheel rim is thicker seems to compensate nicely.
The hub I ended up with is Nardi P/N 4323.00.2202F. So for anyone interested, It bolts right in and the horn wire supplied is a breeze. No need to remove the existing nylon/brass rod - the wire attaches directly to that rod and the Nardi horn push works prefectly.
The wheel itself is very high quality, without a blemish and the rim stain matches perfectly to the rest of the wood.
Best money I've spent on the car to date (well except for those things you cannot see - ie. brakes and shocks etc.)
MrSteeringWheel.com who supplied and shipped the Wheel and hub are in Las Vegas, and they are superb. They helped as much as they could - they could not get responses to our queries of Nardi re the correct hub - Nardi lists two P/N's for hubs for an 85 XJ6, but I took the risk and it all worked out well with this one. I'm so pleased!
I very highly recommend this outfit should anyone consider this upgrade.
Anyone have questions, please feel free to contact me.
Old Feb 26, 2019 | 03:53 PM
sanchez's Avatar
Happy to hear it worked out well for you.
Please post a photo.
Old Feb 26, 2019 | 05:52 PM
iramphal's Avatar
I would..... if I had a camera....working on that!
Old Jan 3, 2024 | 09:53 AM
Excalibur2012's Avatar
Default Camera ?
Please tell me who can afford a Nardi Wheel & Adapter & doesn't have a cell phone ?
Old Jan 9, 2024 | 12:50 AM
LS3COUPE's Avatar
The two different part numbers are for a deformable or solid hub. It took theee months for Nardi just to confirm that to me and then another nine to get the deformable hub to my door.
oxendine
Nov 11, 2024 02:02 PM
FastJag42
20
Mar 27, 2023 04:19 AM
denis4x4
Dec 16, 2021 04:45 AM
sanchez
Feb 9, 2018 03:59 PM
JessN16
Aug 5, 2016 09:24 AM
