No start series 2
Old May 28, 2020 | 05:44 AM
  #41
imaze's Avatar
I bought a brand new Bosch GT40R, I was under the assumption these were the ballast variant?
I'll give what you've recommended a shot though.
Old May 28, 2020 | 06:36 AM
  #42
They are, well done.
That eliminates many things to me.
1) Wiring appears OK
2) Ballast is giving the correct "out" reading.
Your car may not have the Ballast By-pass for start, and that will give that weak spark on crank you have found. I will write that up for you, between sips of Necta, of course, and post back later.
Old May 28, 2020 | 07:20 AM
  #43
Here ya go.
Old May 28, 2020 | 07:24 AM
  #44
imaze's Avatar
Thanks mate, pretty easy to follow.
Do you know how many wires should be hanging off the ignition coil from factory?
Car has not previously had this issue and used to start, there is a immobiliser in the mix, and I'm concerned this may be part of the problem. Have tried to find a basic wiring diagram for the ignition system but haven't had much luck.
Old May 28, 2020 | 07:36 AM
  #45
Pleasure.
Points Ignition had 3 wires, and that memory.
1) Ign +ve on the +ve post. Colour no idea.
2) Distributor Contact Points Earth, on the -ve post. Colour no idea.
3) White with Spiral Plate coloured for the tacho, on the coil -ve post.
IF the car had that ballast system, there would be a 4th wire on the coil +ve post.
The OPUS system, dont remember. It will be in the scribes in the shed somewhere.
If you want the colours, let me know, I will go searching over the weekend, tomorrow is a busy day for us.
Old May 28, 2020 | 07:42 AM
  #46
imaze's Avatar
Yep that's in line with the current wiring then. Last time I fired it up and tried to crank it, the ballast started smoking. Will run through all this over the weekend most likely.
Old Dec 2, 2020 | 06:48 PM
  #47
imaze's Avatar
Thought I'd come back around on this. With COVID and all, motivation was pretty flat but I got myself into the garage on the weekend.
Replaced the battery, ignition coil and vacuum hoses to the carbs and cranked it with a spark tester in play. Great, good strong spark.
Car cranked and still wouldn't start.
My lack of knowledge on SU's comes into play here. So I started playing with the (levers?) that face towards each other on each carb that connect to the bottom of the carb jet assembly. As soon as I opened them up, bam car runs.
So going to do some reading on these to figure out where I've gone wrong, any tips would be appreciated.
Old Dec 3, 2020 | 12:14 AM
  #48
There is a book, from SU Midel, in Caringbah???, and that was 20 years ago. They are THE SU people, and the book is the bible for these carbs and us.
I am assuming from your lever description, you have HS8 SU units, SWEET and SIMPLE carbs.
Basically you have lowered the jets, and that is the same as a choke on a normal carb, and away it went, priceless.
Old Dec 3, 2020 | 03:38 AM
  #49
imaze's Avatar
I definitely owe you a few beers. Not sure where my head was at, but when I put everything back in I left the choke out.
I've refitted the cross bar that links to the two levers for the choke, but I'm missing the fitting that links that bar to the choke pull. Can't seem to find anything amongst the bits and pieces that came off that fits the bill either. Any idea what it looks like?
This will fit the bill I think. http://sucarb.co.uk/linkage-parts/hs...ction-kit.html
Old Dec 3, 2020 | 04:43 AM
  #50
HAHAHA, you are NOT alone.
That is the deal. Ask at Lakemba, they moved, they would have that in stock I reckon.
02 9759 5598
Old Dec 7, 2020 | 03:48 AM
  #51
imaze's Avatar
I called, I ordered, I received, I installed.
And it idles just lovely.
Old Dec 7, 2020 | 05:41 AM
  #52
Like I have said for 50+ years:
Simple cars these Jags.
Old Dec 7, 2020 | 01:50 PM
  #53
JagCad's Avatar
The three "V's" in English, I came, I saw, i conquered...
Carl
Finnmarksvidda
Feb 23, 2020 09:55 AM
salP3082
Jan 11, 2016 02:25 PM
David7
Apr 25, 2015 08:55 PM
Chuckben
Apr 13, 2012 04:01 PM
ryancarmody
Jun 4, 2009 08:29 PM
