Now the ac!!!!!
Old Jul 27, 2020 | 09:42 AM
Darrenmb's Avatar
Veteran: Navy
Default Now the ac!!!!!
I cant win!!!! Picked up car from trans shop this morning, got half way home and compressor locked, pulley locked too!! Bye bye belt!! Had to limp home with no alternator or power steering... not fun!!! I knew compressor was failing as it was noisy when in use, so i didnt use it! , apparently it didnt care! Lol i have a new one ready to go, but now i am going to have to flush everything as well! Anyways.. the drive home( before belt broke) (with 4th gear or overdrive, whatever you want to call it ) was fantastic. 50mph at just over a 1000 rpms...
Will replace compressor this evening and throw a belt on it, just to drive some more, wont hook up hoses or electrical just yet. Need to buy flush!!
then i can give her a bath, been sitting outside trans shop for month.. shes not the cleanest..
Old Jul 27, 2020 | 10:21 AM
At least you had sort of Planned for this happening.
On my car it would be a complete Disaster as I have one of those Ancient compressors half as long as the engine block and about as plentiful as hen's teeth.
Old Jul 27, 2020 | 12:02 PM
JagCad's Avatar
Darren:
It is fun!!! Sith no power to th
e compressor, the clutch will not engage and it might not spin. Or if lcked, as yors is, not lock the belt. or ??? Mine id in my 85 150. I cut the belt and lost nothig. but cool, and it was a hot day!!1
Another Harrison or a better unit?
Elinor:
Did not know that big old Harrison was that rare??
A few years a go, a guy was looking for a York. I had one. now, that is rare...
Old Jul 27, 2020 | 12:30 PM
Darrenmb's Avatar
Veteran: Navy
New one has been on bench for 2 weeks now, as you know Carl, the lt1 only has the one belt, luckily waterpump is driven from cam.
Old Jul 27, 2020 | 06:56 PM
geneo's Avatar
other than that Mrs Lincoln, How was the drive home with the good tranny?
Old Jul 28, 2020 | 07:15 AM
Darrenmb's Avatar
Veteran: Navy
I installed the new compressor but failed to remember to buy a a new belt... ( old age.. lol) battery was on charger all day so wasnt afriad to go for a short drive.. gotta love it!!
Old Jul 28, 2020 | 08:07 AM
Jose's Avatar
Retro Air sells a revised / upgraded Harrison compressor for the XJ-6 . They even have a chromed version if you want to spend the money. Supposedly more efficient than the original Harrison.
www.retroair.com
Old Jul 28, 2020 | 07:31 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
What diameter tires are you running Darren?
Dave
Old Jul 29, 2020 | 06:05 AM
Darrenmb's Avatar
Veteran: Navy
Tires are.215 70 r 15 rear is stock,
Old Jul 30, 2020 | 06:10 AM
Darrenmb's Avatar
Veteran: Navy
Just got a tape. Measure out, and tire looks.to be 26 inch diameter
Old Jul 30, 2020 | 11:07 AM
LT1 jaguar's Avatar
Thanks Darren, that's what the old 215-70's are that came on my car. Have you calibrated your speedo/tach? Online calculator shows with 2.88 gears, .70 overdrive, 26" tires, at 50mph the rpm should be right at 1300rpm.
Dave
Old Jul 30, 2020 | 12:09 PM
Darrenmb's Avatar
Veteran: Navy
Dave, i just sent my tire size and rear ratio to tuner and left it to him, havent checked anything yet, nor have i checked to see if speedo reads same as vss output. I can fine tune the speedo with the Dakota digital sgi 5e its currently just set at 2 for the multiplier, which i should think would be close as pcm puts out 4000ppm and speedo needs 8000, or vice versa, cant remember right now...
Old Jul 30, 2020 | 04:37 PM
Yellow series3's Avatar
Side question. In the photo it looks like the needle on the volt meter is curved. Is it really that way or just a photo anomaly? If curved I wonder how it got that way. Sorry to go off topic. Air conditioning is good.
Jeff
Old Jul 30, 2020 | 05:02 PM
Darrenmb's Avatar
Veteran: Navy
Hahaha well. Now i need to go home and look at my.volt meter. Hopefully its judt an optical illusion!!!
Old Jul 31, 2020 | 06:22 AM
iramphal's Avatar
The needle of my voltmeter in addition to being lazy to wake up, also has a kink in it, albeit not as much as this one in the photo.
Ian
Old Aug 6, 2020 | 03:22 AM
Andy T.'s Avatar
Strangely, the needle on my car’s voltmeter is also bent like the one in your photo!
Old Aug 6, 2020 | 11:24 AM
I'm intrigued by this.
I just looked at Nix's needle from all possible perspectives, and it's Straight.
Of course, she Is a Series 2.
Old Aug 6, 2020 | 11:26 AM
Darrenmb's Avatar
Veteran: Navy
Well I never actually went and looked to see if its bent as bad as it looks, been busy with other stuff, hopefully i will remember to look tonight when i get home..
adamc
Nov 20, 2022 12:59 AM
john_cook12
Aug 10, 2016 11:37 AM
adenshillito
Jun 17, 2015 06:17 AM
NtAFord
Aug 20, 2014 10:23 AM
matl
May 25, 2010 11:38 PM
