Painting over Imron
Old Aug 11, 2021 | 07:27 PM
DBaer's Avatar
Default Painting over Imron
I tried asking this question on some older posts but no response so i am hoping the experience of the group can help. The 1971 XJ6 i bought this spring was stripped of paint, rust repaired, and repainted with Imron. Overall it is not bad but there is some small bubbling and the fingernail thickness chips! I plan on taking the glass out along with the interior etc. and repainting. I dread the thought of taking the Imron back to bare metal. Does anyone have any experience painting over Imron with a two stage finish? A few photos that came with the car along with a few now attached.
Always appreciated!
Old Aug 12, 2021 | 09:40 AM
Fraser Mitchell's Avatar
Well, this assumes we all know what IMRON is !
I quick internet search found this, (there are other articles)
https://www.autobody101.com/forums/viewtopic.php?t=2637
It looks like it is a coach-type paint used to paint trucks and coaches. Downside of these paints is that it is very difficult, even impossible to polish smooth, but that doesn't matter with the vehicles that get painted with this stuff. My experience is that normally when trying to paint over these with cellulose paint, wrinkling will occur. However cellulose is no longer used, but even so, the wrinkling was from the solvents, so it's always best to test a small inconspicuous area first. With clear-over-base paint, the colour coat is water-based.
Its really a matter of trying things out, I reckon and also try to find a paint shop that can give advice.
Old Aug 12, 2021 | 09:58 AM
DBaer's Avatar
Thank you, This was my initial thought, that I would take one of the fuel tank skirts and give it a try. I will keep you posted!
Old Aug 12, 2021 | 12:39 PM
icsamerica's Avatar
All paints are only as good as what is beneath them. If the Imron is stable, sand it back as far as you can then do your sport and chip repairs. Most modern paints are very flexible and will work over a variety of surfaces such has metal and flexible urethane bumpers so going over imron should be ok too.
Old Aug 12, 2021 | 02:39 PM
sanchez's Avatar
IMRON is a very durable paint, but is susceptible to chipping because it dries to a very hard finish. Stone chips happen very easily.
I have painted over IMRON in the past.
Prep the car as is. (Wear proper gear)
Do all of your spot repairs.
Sand the IMRON paint smooth. (Not very easy to do)
Seal the IMRON paint using an EPOXY Primer/ Sealer.
Prep EPOXY primer/sealer.
Apply Base Coat.
Apply Clear Coat
Old Aug 13, 2021 | 12:22 PM
JagCad's Avatar
Way back when, we knew that painting Laquer over acrylic AKa cellulose and enamel would not work. The solvent in lacquer/cellulose cuts enamlor acrylic.
Before the strong sealers, it meant bare metal or use enamel/acrylic...
Aye, the base is great,if in good condition. going to barte metal needed only in extreme cases.
From a non expert...
Old Aug 13, 2021 | 06:50 PM
DBaer's Avatar
Sanchez, This is what I was hoping to do. Imron was the rage for a while around here. My arms are already tired but I am up for it. Thank you for the advice.
Old Aug 13, 2021 | 06:52 PM
DBaer's Avatar
JagCad, I will run with that theory, and an experiment will tell. I will document the results! Thank you as well
Old Aug 19, 2021 | 09:38 PM
alabbasi's Avatar
Imron is a tough old paint. Are you sure you can't polish it?
Old Aug 22, 2021 | 01:34 PM
DBaer's Avatar
It certainly is tough! There are chips and some rust that needs to be addressed so i am faced with a repaint. Not the end of the world!
owas
Feb 20, 2024 01:42 PM
bic_bicknell
Jul 29, 2021 08:19 PM
julien4020
Aug 19, 2017 01:34 AM
58mk1x2
Aug 3, 2017 02:33 AM
AussieTimmeh
Dec 6, 2016 08:44 AM
