Rack removal question
Old Jan 15, 2021 | 02:41 PM
worzella's Avatar
Default Rack removal question
Planning to remove my 86 SIII rack soon and I know I have to disconnect lines, tie rod ball joints and there are three
mount /bushing points to unbolt. But as far as disconnecting from the steering column, I am guessing this
pinch joint inside the red box below is the last thing I need to undo.
Can someone verify that? I hope at that point the rack just drops out
Thanks - Randy
Old Jan 15, 2021 | 04:07 PM
Jose's Avatar
the pinch bolt at the steering column shaft is the first one you should do, and to split apart the pinch bolt tabs second. The hoses third. the tie rods fourth. then the two bracket bolts fifth, holding the rack with one hand as you remove the second bracket's bolt.
You don't want the rack hanging its weight from the steering column shaft.
Old Jan 15, 2021 | 04:38 PM
worzella's Avatar
Thanks Jose for the order info.. very helpful.. but when you say "pinch bolt", Is that what I highlighted in red.. I believe so.
Thanks - Randy
Old Jan 15, 2021 | 04:48 PM
Jose's Avatar
Originally Posted by worzella
Thanks Jose for the order info.. very helpful.. but when you say "pinch bolt", Is that what I highlighted in red.. I believe so. Thanks - Randy
Randy, yes. that is the pinch bolt. And you might need to spread the - what do you call them - "legs" of the bracket after removing the bolt, to release the shaft.
same thing as spreading a battery connector so it will fit over the pole or to remove it.
bknorwood
Oct 1, 2020 10:13 PM
CZSteve
Oct 2, 2019 05:32 AM
stevepaa
Aug 10, 2019 03:03 PM
Fla Steve
May 20, 2018 02:59 AM
