Rear Differential Compatability
Dave
Dont forget, if buying a Dana44 ring/pinion, you need the one that is dual drilled.
also, you will need the flange adapter as the pinion has different splines than the jag unit.
if you are using an xjs dana44 (the one with no drain plug) the flange adapter is not needed.
