Rear Differential Compatability
Old Apr 25, 2025 | 11:38 AM
LT1 jaguar's Avatar
Active Streak: 60 Days
Originally Posted by Doug
I think I'd like to do this.
Do you still have the part numbers?
Or do you simply order these parts for a Dana 44 ?
I have everything, if you can send me your email address in a PM I'll send you part #'s, tips, notes.
Dave
Old Apr 26, 2025 | 09:32 AM
nickr76's Avatar
Dont forget, if buying a Dana44 ring/pinion, you need the one that is dual drilled.
also, you will need the flange adapter as the pinion has different splines than the jag unit.
if you are using an xjs dana44 (the one with no drain plug) the flange adapter is not needed.
Vladm69
Apr 16, 2023 07:47 AM
Mozambique
Mar 22, 2023 09:08 PM
Nottrndy
Jul 3, 2018 06:56 PM
Jarred Fitzgerald
Dec 11, 2016 03:18 PM
Rich B
Aug 5, 2015 08:34 PM
