Remote start/keyless entry mod
Old Oct 11, 2018 | 09:43 AM
Camerenxj6's Avatar
Default Remote start/keyless entry mod
I'm thinking doing keyless entry on my series 3 but also wanting to do remote start and wondering if anyone has done the remote start side of this question
Old Oct 11, 2018 | 11:21 AM
benji808's Avatar
Not in the Jag, but a few years ago I installed a $20 Bulldog remote start/keyless entry unit in a '86 Lincoln. It took me an afternoon but was fairly straightforward and a lot of fun afterwards. You're basically just bridging the 12v Constant wire and the ignition feed wire with a button-activated switch, so I don't anticipate there being an issue in the Jag, assuming you use your wiring diagram (there's a helpful reference in the "how-to" sticky threads)
Not 100% sure, but depending on the year the keyless entry may be a bit more complicated...I think the later Series IIIs had mechanical actuation for unlocking, rather than an electric motor, which means you would have to install a motor of some sort for a typical keyless entry to work. Again, I don't have experience working on this particular vehicle, but have done it on a different one. Here's an old thread with some insightful discussion: https://forums.jag-lovers.com/t/xj-door-locks/161095/6
Old Oct 11, 2018 | 08:18 PM
Doug's Avatar
Never did a remote start on my Jags so can't comment. Can't think of any reason, offhand, why it wouldn't be possible.
Remote keyless entry is doable on a Series III but the difficulty depends on which of three possible locking systems you have.
1) The early Series IIIs (until '82 or so) has the Lucas solenoid system where the central locking could be operated from either front door. This is because the solenoids in both front doors act as both solenoids (operating the lock linkage) and as controllers (commanding the solenoids in the other doors)
2) The mid-range Series IIIs used the Lucas solenoid system but the unit in the driver's door was a controller only. The units in the the other doors (and trunk) were slaves.
3) The later Series IIIs (roughly mid-85 to 92) used Kiekert lock motors (not solenoids). And, as with #2 above, the unit in the driver's door is a commander only...and all the others are slaves.
The Lucas systems uses relay; the Kiekert system does not.
If you have system #1 adding RKE is easy. Your RKE unit simply powers the existing relays.
If you have system #2 or #3 you need to install and additional motor or solenoid (triggered by your RKE module) in the driver's door to operate the lock linkage, imitating the action of turning the key in the lock and thus operating the command unit which, in turn, operates the slave units.
Old Oct 12, 2018 | 04:43 PM
Yellow series3's Avatar
Doug, you are the Yoda master of the Forum. My 79 SIII opens all doors from the passenger (US) side and yesterday I bought a 87 SIII and thought it weird that the door on that side didn't open the other door locks but the drivers door did. Now I know why. Actually, being the chivalrous gentleman that I am I like being able to open my wife's door and have that open all doors. With the 87, I have to unlock her door then go around and use the key again on my door.
With regards to keyless entry systems, Bulldog had a nice inexpensive unit that would work well on the older models (a momentary pulse of 12v+ to the relay). Unfortunately, they went bankrupt and are no longer available. Anyone have a good replacement for that? A simple keyless system with on-board relays and reasonably priced?
Old Oct 12, 2018 | 08:46 PM
Doug's Avatar
I've used many Bulldog systems; always good luck with them. When did they go under? As of a year or so ago there were many for sale on Ebay, etc
Old Oct 12, 2018 | 09:55 PM
Yes, they were just what I needed. I put off the project until I had time to install it and they were no longer available. I looked them up, they are (were) located in Ohio where I live, and boom the company is gone. Maybe they will get back in business some day.
Old Oct 13, 2018 | 10:20 AM
JagCad's Avatar
More than likely not. the market shrunk. Modern cars do that stuff.
Might look in to the HoTrod sites. Lots of electric stuff going on there.
For me, aye my 83 opened from the driver side. so, when I as a the gentleman I am, opened the door for my dear departed. I hads to do that pirouette thiong.
Carl
Old Aug 20, 2019 | 11:33 AM
Adrian L's Avatar
Bulldog is gone?! I had one (keyless entry) in my '85 GMC van and it worked great---for about 3 or 4 years until it didn't work at all. (EDIT: you can still find them on Ebay)
On a related note, how easy or difficult is it to add power locks to a Series 1? Can I take apart an S2 or S3 door and move the stuff over or is it more involved?
Old Apr 22, 2020 | 08:14 AM
Roger Mabry's Avatar
I only added it to my drivers door..have the parts to do the others but do/did not care - since I ride alone 99.9% of the time...would be more interested in doing a trunk
remote lock.
Old Jan 1, 2022 | 03:54 PM
ruffindustries's Avatar
Where you able to move forward with the key less entry?
Roger Mabry
Apr 21, 2020 06:06 AM
kesslari
Jun 28, 2016 02:01 AM
bradstuff
Sep 10, 2014 01:43 AM
sherbercars
Jul 7, 2013 03:32 PM
Sarc
May 4, 2013 01:20 AM
