Ride height-rear spring spacer
Old Jan 11, 2021 | 11:37 PM
Doug's Avatar
Default Ride height-rear spring spacer
While changing my rear shocks recently it seemed like a good time to fix my rear ride height issue. In this case the problem wasn't front-vs-rear but, rather, left-vs-right. The left side was just slightly lower than the right. Not by much, maybe 10mm or so. But it's one of those things that once seen cannot be unseen . It was a bit of an itch.
While the springs were off the car I stood them up alongside each other; one of the left springs was about 3-4 mm shorter than the other. I guess it has gone a bit saggy over the years?
Anyhow, on reassembly of the springs and shocks I installed a single spacer under the one short spring, hoping for the best but not fully anticipating a fix. Each spacer is 3mm, by the way.
It worked. No more tilt to the left.
Fingers13
Oct 12, 2019 03:13 PM
petemohr
Oct 11, 2019 03:31 PM
Yellow series3
Aug 11, 2019 03:15 PM
edreddy
Sep 23, 2018 06:28 AM
Dave1109971
Oct 19, 2015 03:05 AM
