Rough engine at 1500RPM
Old Apr 17, 2013 | 05:59 AM
Elbartus's Avatar
Default Rough engine at 1500RPM
hi all,
i tried to do a search but couldn't find anything, i just noticed when driving and rpm is around 1500 i seem to get a strong vibration but clear of 1500 its fine.....is it possible to have a flat spot
there was no loss of power just a vibration
Old Apr 17, 2013 | 08:05 AM
Doug's Avatar
I'm not entirely clear on the symptom, as "rough engine" and "engine vibration" are different things to me.
So, does it feel like something is out of balance (vibration) or does it feel like the engine is misfiring/cutting out (rough engine)?
If you rev the engine to 1500rpm in neutral do you still feel it?
There is no road speed aspect to this? Purely an engine speed thing?
Old Apr 17, 2013 | 08:41 AM
Elbartus's Avatar
Yes i get the same result in Neutral as well as will on the road with engine running at 1500rpm, and yes i guess rough was a bad term . vibration would be more correct
Old Apr 17, 2013 | 03:29 PM
Ahabiam's Avatar
Quick engine mount check for starters. Verify they do not appear to be torn/seperated and that they are still bolted to the engine - 1/2 inch nut I think on both. I saw a video where the mounts had loosened up (Nut was actually gone...) and the engine actually shifted some causing a vibration.
Old Apr 19, 2013 | 11:22 PM
Doug's Avatar
Good advice on checking the mounts
Add transmission mount to the list, though. The the mounts collapse the transmission can become grounded to the main mount bracket and transmit vibrations into the body.
There's a "tongue" that runs below the transmission mounting. It need to be parallel with the transmission. Use the transmission pan for a sight line. If it isn't, the mounts are sagging
D.K
Dec 10, 2023 02:05 AM
GordoCatCar
Jan 2, 2017 01:10 PM
cissdm
May 3, 2016 06:02 AM
Bowman
Sep 3, 2015 03:17 PM
OkieTim
Sep 2, 2015 12:48 PM
