S3 Rear motor mount
Old Mar 2, 2020 | 08:28 AM
quartetchiang's Avatar
Default S3 Rear motor mount
Do you see anything wrong in this picture? S3 4.2 rear motor mount.
Old Mar 2, 2020 | 07:56 PM
YEP. Cotton Reel is uninstalled.
Have a read. It is V12 to start with, the 1./2 size engine is further down.
Still clear as mud, ask, I/we can walk you through it.
Old Mar 2, 2020 | 11:34 PM
Doug's Avatar
Plus the two rubber blocks are sagging
Old Mar 3, 2020 | 09:00 AM
And my question is, What might have caused the two rubber mounts to sag? This geometry surely will cause the prop shaft to go out of phase, right?
will the missing cotton reel cause the sagging?
Old Mar 3, 2020 | 09:24 AM
Dear Grant Francis:
Fun read!! Some digestion needed though on my part. Trying to picture my BW 66's arrangements.
Old Mar 3, 2020 | 09:25 AM
Rubber sag is usually, but not always, caused by Great Age, heat and accumulation of escaped engine oil and road grime.
Old Mar 3, 2020 | 10:06 AM
Dear Grant Francis:
By "cotton reel", are you referring to #3 in the diagram?
Old Mar 3, 2020 | 04:29 PM
Jagboi64's Avatar
Yes.
Old Mar 3, 2020 | 06:19 PM
Dear Grant Francis:
Its like Lego for Adults.
Over complicated, 99% assembled WRONG by someone, and usually parts missing.
I am trying to find a parts drawing of the assembly, but not enough coffee yet,.
Old Mar 3, 2020 | 06:24 PM
As Elinor said, OLD AGE, just like us humans.
Out of phase, NO, out of alignment, YES.
NO, the mis-fitted cotton reel will NOT cause the sagging. Other issues, vibration, banging, rattling etc etc, YES.
Old Mar 3, 2020 | 06:37 PM
Dear Grant Francis:
"vibration, banging, rattling" --- I have precisely all those!!
Do you have a diagram of the BW66 version assembly? I do not have the factory service manual. And per chance that I had a glance of it, it did not seem to be very clear. Also the assembling instructions were rather vague. It'll be great if the diagram comes with part numbers attached.
Old Mar 3, 2020 | 11:31 PM
Jagboi64's Avatar
Jaguar has parts diagrams available on their Classic parts website. Here is the XJ6, the 4.2 transmission mount is on page 46: https://parts.jaguarlandroverclassic.../gearbox/#p=46
The 3.4 mount is different, and on the previous page. Numbers in brackets after the part number on the drawing indicate quantity.
Old Mar 4, 2020 | 02:29 AM
OK, 6 beers down, and I have included the 6cyl (1/2 size engine) in the Transmission Doco.
Had it done at 2 beers, but Cyber Space stole the damn thing, so I wrote it again.
Old Mar 4, 2020 | 06:24 AM
You guys are ferociously fabulous!!!
Old Mar 8, 2020 | 04:50 AM
Dear Grant Francis:
Can you verify the error in the TH400 drawing being #27 and #28 should be reversed? Also, Some mentioned that the spring itself is directional, that it can only be one side up. Can you verify this?
Paul
Old Mar 8, 2020 | 05:15 AM
YEP, #27 and #28 are in the wrong position.
The V12 mount has ONE "sleeve" as a machined section of the "pin", so then the washer, followed by the spacer.
The 6 cylinder "pin" is basically a BOLT, and so you have e spacer/washer/spacer.
SIMPLE
The spring is NOT ended. It will fit either way, BUT, the V12 has only ONE rubber seat on the bottom, the 6 cyl has a rubber seat on each end of the spring, AND, the V12 and 6 cyl springs are NOT the same.
quartetchiang
Feb 20, 2020 04:58 AM
littlehandegan
Jan 2, 2020 08:10 PM
PeteK812
Jul 21, 2018 04:26 AM
plums
Nov 23, 2012 01:33 AM
