S3 XJ6 Boot lock
Old Mar 17, 2020 | 08:34 AM
Justin84's Avatar
Default S3 XJ6 Boot lock
The boot lock on my car won't turn, does anyone have a part number for the boot lock or a diagram of how it works?
I have a lock picking kit so would like to have a pop at picking the lock.
Old Mar 17, 2020 | 10:24 AM
Jose's Avatar
are you inserting the correct key ?
Old Mar 17, 2020 | 10:52 AM
Justin84's Avatar
Yes, at least I would imagine so from what the owners manual says. Just in case I am doing something wrong, the process is the pure silver key with the Leyland logo on it goes in the lock in either direction and turns clockwise then the boot opens from the latch. The boot isn't unlocking from the drivers door either so I'm inquiring the cost of a full lock set from someone breaking a Jag so that even if the central locking isn't working properly I can still use a key to get in.
Old Mar 17, 2020 | 12:10 PM
Jose's Avatar
unlocking the doors via rhe driver's door does not unlock the trunk lock, you can only lock the trunk lock when locking the driver's door.
Old Mar 17, 2020 | 12:13 PM
Justin84's Avatar
unlocking the doors via rhe driver's door does not unlock the trunk lock, you can only lock the trunk lick when locking the driver's door.
Ah, I was under the impression that when you unlocked the drivers door it unlocked the boot but if you then locked the car and unlocked it from the inside the boot wouldn't open.
Old Mar 17, 2020 | 12:19 PM
Jose's Avatar
no, the trunk/boot lock can only be unlocked manually, but it can be remotely locked, (only locked) , from the driver's door.
So you might try removing the license plate, and through one of the oblong holes on the right side, grab the connecting Rod and pull it UP to try opening the boot lid. Thin needle nose pliers work best.
Old Mar 17, 2020 | 12:21 PM
Justin84's Avatar
Ah I'll give that a whirl tonight if I get a chance. Thanks!
Old Mar 17, 2020 | 12:36 PM
Jose's Avatar
here's how it looks behind:
Old Mar 17, 2020 | 01:23 PM
Justin84's Avatar
That's really useful, thank you! Now I know roughly where to aim.
Old Mar 17, 2020 | 02:12 PM
Jose's Avatar
what year is the car? some early XJ came with 3 keys, one exclusively for the boot lock.
My 1984 has two keys, one exclusively for the ignition switch, (the one with the black plastic cover), and one for the glove box, doors, and boot.
Old Mar 18, 2020 | 03:15 AM
Justin84's Avatar
I've only just bought the car, it only came with two keys, the ignition key and the dome headed key.
The owners manual says three keys:
Ignition Key
Dome headed key - opens everything (boot, doors and glove box)
Dimple headed key - only opens doors (valet key)
Old Mar 18, 2020 | 08:02 AM
Jose's Avatar
try injecting rust blaster fluid into the lock, and spraying it on the key too.
then exercise the lock back and forth injecting more rust blaster. It should open.
Old Mar 19, 2020 | 02:02 AM
yarpos's Avatar
Ignition Key
you are just giving it a qtr turn anticlockwise and then operating the lever arent you?
just asking as its a new car to you and the boot arrangements and the lock operation arent like other cars
Old Mar 19, 2020 | 07:48 AM
Jose's Avatar
I also forgot to ask if he is pushing up on the lever under the plinth, (or whatever you call it), after turning the key to the left.
Old Mar 30, 2020 | 07:15 AM
Justin84's Avatar
Quite embarrassed really, bit of WD40 and it freed it up really quickly. Before spraying the WD40 in the barrel it wouldn't budge a fraction so I thought it was buggered. Just bought some WD40 Lithium Grease for the hinges on the boot (and door handles) as it's pretty stiff to open and close.
Old Mar 30, 2020 | 07:44 AM
Jose's Avatar
happens to everybody!
Old Mar 30, 2020 | 12:45 PM
JagCad's Avatar
A bit of grease dews so much!! Some good, some not so much!!!
Cabin fever humor!!
Carl
Old Mar 30, 2020 | 12:51 PM
JagCad's Avatar
Hum, that renders my dimple key useless. Neither door lock works!! diver door locxk merely spins with no results. Passenger door lock will not even turn. Same result, none!
Original ignition key, a replaced one, obsolete. lock replaced with NOs unit via David Boger. works so nice..
But, yeah the hump key works the gas caps and boot perfectly!!!
And, although have not driven for a spell, the Jaguar fires each ands every time. Battery go down after a few days issue gone.. I credit the added ground cable. why< not sure, but it worked!!
Carl
Old Mar 31, 2020 | 04:42 AM
Justin84's Avatar
I need to investigate mine a bit more, was reading up yesterday about the cold start injector as mine cranks for quite some time before firing up but is fine after it has warmed up. Ordered some new HT leads too as I'm pretty sure the ones on mine are original and if they're anything like me they're passed their best by date by now.
Steve's XJR
Nov 8, 2015 04:11 PM
haswell4
Feb 3, 2015 12:22 PM
Chas2008
Mar 7, 2013 11:23 AM
goldenbrown
Jan 27, 2011 05:51 AM
