Series 2 doors in series 1 car?
Old Jan 14, 2015 | 03:56 AM
Wilfred88's Avatar
Default Series 2 doors in series 1 car?
For my xj6, I want some replacement doors. These will be used while I restore the original doors, as they have some rust.
S1 scrappers are hard to find, but I am offered an S2 for almost no money. Will these doors fit?
Same size, same hinges?
Anybody knows?
Old Jan 15, 2015 | 02:09 AM
Wilfred88's Avatar
nobody?
Old Jan 15, 2015 | 09:12 AM
weattg44's Avatar
Only one way to find out for sure...
Old Jan 15, 2015 | 09:53 AM
Civicalized's Avatar
I have no idea for sure, but looking at pictures of two from basically the same angle and distance, I'd say the fronts would probably work, assuming hinges line up. Rears may depend on which wheelbase the S2 donor was. If I recall, some came with the shorter wheelbase, same as the S1, but then they went to strictly the longer wheelbase in later S2. To me, it seems as if the extra inches were added to the rear doors. Shape and everything looks the same to me as well. I'll attach some pictures I found online. As weattg44 stated, "only one way to find out...". I'd be interested to see if they'd work or not.
Old Jan 16, 2015 | 02:47 PM
Fraser Mitchell's Avatar
AFAIK you'll be OK with the swap here as there were minimal changes bodywise but the Series 2 introduced the long wheelbase cars, so there are two lengths of rear door. Eventually all cars became long wheelbase and the short ones ceased. If there are minor differences, I am sure they can be fettled out.
Old Jan 19, 2015 | 05:43 AM
Wilfred88's Avatar
I got the series 2. Think I will fit. Well let you know when I get to work on it.
Old Jan 19, 2015 | 08:32 AM
Roger Mabry's Avatar
Default Front door hinges
If you plan to change the hinges.. you have to really loosen/almost remove it) the front fenders to get the long bolts out... I changed my hinges for the later model ones from a S1 (72-73) that have the big spring... they worked
out well.
I never saw a SWB SII so I cannot attest to those doors fitting.. have rear door thresholds for them and they are longer.
Old Jan 20, 2015 | 02:39 AM
Wilfred88's Avatar
I will take off the fenders indeed. Makes working on the hinges much easier, and I want to work on the fenders anyway. Cannot do full resto, cause don't have a garage. Now I can swap body panels/doors and restore the panels one by one.
Old Nov 27, 2018 | 04:25 PM
xjaysix's Avatar
Anybody knows?
they should fit, as mentioned depends on tbe wheel base S2 did make a short wheel base i just sold one, but they are hard to find,
S2 does not have a front 1/4 window that can be opened its fixed on the S2
Old Nov 30, 2018 | 11:03 AM
Robert Wilkinson's Avatar
The door latches are different, starting in the last year of the S1 (73) and continuing into S2. So IMHO S2 front doors would not interchange with S1 except possibly 73.
Trujillo D. Joseph
Oct 18, 2019 03:55 AM
msdg137
Sep 16, 2015 06:24 AM
ahunt4
Sep 4, 2015 02:59 AM
Mr. Mohr
Aug 27, 2015 10:15 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
