Series III Accelerator cable. help!
Old Nov 8, 2023 | 06:41 AM
Nathanyork78!'s Avatar
Default Series III Accelerator cable. help!
Anyone have a spare? Can’t find one for sale for some reason. Any good used ones?
Old Nov 8, 2023 | 12:08 PM
Jose's Avatar
I have a new one but don't want to part with it for the same reason you can't find one. NLA.
Try David at www.everydayxj.com
Old Nov 8, 2023 | 04:11 PM
slofut's Avatar
I'd suggest David Boger too. Is yours broken?
Old Nov 8, 2023 | 05:04 PM
Andy T.'s Avatar
When I wanted to replace my accelerator cable, I took the old one to the high street motor factor and found a similar one in stock which was from some modern Japanese car or other. I used the original Jag outer cable and had to change the nipple over from my original inner cable to the new one to suit.
It is usually only the inner cable that needs replacing.
I do this sort of thing quite a lot to save having to import parts which are fairly generic.
Old Nov 8, 2023 | 06:00 PM
Doug's Avatar
LHD or RHD ?
5.3 V12?
4.2 six cylinder ?
3.4 six cylinder?
Old Nov 8, 2023 | 08:52 PM
slofut's Avatar
Originally Posted by Doug
LHD or RHD ?
5.3 V12?
4.2 six cylinder ?
3.4 six cylinder?
Doug, I just realized you have a TR6 with a V8! How does the frame/front suspension and rear end fair with the extra torque? Btw.. I think you've been on the other forum as long as I have? Since 84 or so?
Old Nov 8, 2023 | 09:54 PM
Doug's Avatar
heh heh
I'll put it to you this way: I refer to the car as "The Death Trap".
Been on J-L since 2000. Been here since '09 I think
Old Nov 9, 2023 | 08:29 AM
slofut's Avatar
heh heh
Ok cool, I have the motor out of mine and of course all kinds of things running through my head. I think I'll leave well enough alone. I loooove the sound of that little six anyway
Old Nov 9, 2023 | 07:03 PM
Bill Mac's Avatar
When talking about replacement cables don't forget there are hundreds of non-automotive uses for cables in machinery.
Some examples include everything from motor mowers to bulldozers and anything in between.
I recently had a 1952 BSA motorcycle clutch cable made at a local cable shop and they were able to replicate the exact cable with correctly swaged fittings and the price was quite reasonable.
It turned out that they also manufacture control cables for non-certified ultra-light aircraft.
So, it is worthwhile to think "outside the box" when chasing down alternative parts.
Old Nov 28, 2023 | 02:40 PM
Jose's Avatar
Default Accelerator Cable
UPDATE:
contact www.speedycables.com in the UK, they manufacture all types of cables, you might need to send them your broken cable.
Harvestwidow86XJ
May 25, 2021 10:54 AM
iramphal
Sep 24, 2019 02:27 PM
gtjoey
E type ( XK-E )
Aug 9, 2018 10:48 AM
Purplemaverick
Jul 3, 2017 03:43 AM
adenshillito
Feb 28, 2016 08:41 AM
