SIII Front subframe bushing/mount
Old May 3, 2025 | 02:30 PM
benji808's Avatar
Default SIII Front subframe bushing/mount
Engine is out, and I figured replacing these would be straightforward. Car is on jack stands at the lift points, I have the nut off the bottom, and both bolts unscrewed, but there is not enough clearance to remove the bushing/mount. Do I just need to push on the cross member to create the separation, or do front mounts and/or axle/steering column have to be removed?
Thank you!
Old May 3, 2025 | 10:13 PM
benji808's Avatar
I had to remove the nuts on top of the shocks in order to drop the subframe enough to remove the mount/bushings. Weird I haven’t seen the manual or any other guides reference that, but glad it worked!
MussieRon
Oct 31, 2024 06:22 PM
brinny
Mar 29, 2019 10:05 AM
EcbJag
Jul 27, 2018 07:07 PM
Carnival Kid
May 16, 2018 07:51 PM
yachtmanbuttson
Jun 29, 2016 12:51 PM
