Stake Down Question
Old Sep 6, 2018 | 08:43 AM
Gismo's Avatar
Default Stake Down Question
I’m going to install stake downs on the exhaust side as a precaution. Am I correct in assuming you only need one per tappet follower? I.e. you only need 180 degree coverage rather than 360 degrees per follower?
Also should the stake down be installed up, down left or right? I’ve seen them up and down.
Thanks.
Old Sep 6, 2018 | 09:02 AM
motorcarman's Avatar
There are 3 holdowns for 6 exhaust tappet guides. They only hold an edge and that is all that is needed.
I have only used them on the exhaust side and the plates are normally installed on the lower part of the tapper valley.
bob
Old Sep 6, 2018 | 09:04 AM
Jose's Avatar
if it ain't broken don't fix it.
Old Sep 6, 2018 | 09:10 AM
Gismo's Avatar
Thanks Bob. Jose I don’t want to get into a fracas. I understand this issue is almost as fraught as the leaper/no leaper debate and I do worry about the mechanic making a mistake in the installation. But should I just be attentive to a change in noise and if so do it then? I don’t want to be pennywise and pound foolish here but if it’s done I don’t have to worry about it no?
Old Sep 6, 2018 | 09:45 AM
Jose's Avatar
if you don't hear a rattling noise coming from the exhaust side of the cylinder head, your engine is one of the few engines that does not need tha fix.
Old Sep 6, 2018 | 08:53 PM
Doug's Avatar
There's an argument to be made that if a tappet guide problem was gonna occur, it would've already occurred in the last 31 years.
Installing a stake down is like insurance.
Old Sep 7, 2018 | 08:39 AM
JagCad's Avatar
Doug: ;
Yeah, that is the phrase. AKA "sleep at night" !!!
Carl
Old Sep 7, 2018 | 09:15 AM
Gismo's Avatar
As long as your tech doesn’t mis-drill the holes, penetrate the block or get filings in the engine while doing it . . . .
Old Sep 7, 2018 | 12:43 PM
moronthethrottle's Avatar
That's not good. I hope that's not your current experience!
XJDanny
Jul 31, 2018 08:31 AM
Hafrod
Feb 17, 2016 07:00 PM
Starlifter
Nov 14, 2010 06:53 PM
moronthethrottle
Apr 30, 2009 04:06 PM
