Starting Troubleshooting Help
Old Jun 4, 2022 | 09:12 PM
Huntervision's Avatar
Default Starting Troubleshooting Help
Hi everyone. I have a 1974 XJ6L, USA spec, for which I would like your guidance on troubleshooting a start problem. For background, I have owned the car for 40 years. Most recently, It was garaged for three years as I chased what I thought was a carb issue, but after five months in the shop, turned out to be a combination of bad auto chokes on the carbs, plus a bad head gasket and a distributor that was a mess.
So, it has been running well, but for the starter being a bit reluctant on initial start up. I was not surprised since it had been abused during the last couple of years and was about 35 years old. Battery new, cables OK.
So, recently, I went out to hot start it, and I got nothing but a "click" when moving the ignition switch to start. So, I replaced the starter with a rebuilt unit (not having time to get one of the high torque ones). Nine hours later...still "click".
So, I would like to follow this in a logical way with my voltmeter. Since all the smog stuff is piled on top of everything else, I have to access from under the car. So, I would like to get suggestions from those smarter than I am of a suggested troubleshooting sequence.
Thanks in advance for your patience and help.
Old Jun 5, 2022 | 05:06 AM
Malcolm Ridgway's Avatar
Default Troubleshoot
Presume you have checked the battery?
Old Jun 5, 2022 | 06:17 PM
Yup, a heavy-duty new battery at 12.78 volts resting.
Old Jun 6, 2022 | 07:35 AM
yachtmanbuttson's Avatar
Check the braided ground connection from the engine to the body underneath?
Old Jun 6, 2022 | 10:22 AM
Will do.
Thanks.
Old Jul 13, 2022 | 04:28 PM
KarelH's Avatar
Default Please advise, gasoline is flowing from the overflow
gasoline flows from the green tube
_____________________
1974 XJ6 (added by GGG)
Old Jul 17, 2022 | 08:30 PM
I found the issue. It was the wire from the relay to the solenoid. It looked OK but had obviously deteriorated. I made up a new one and all is well.
Old Jul 18, 2022 | 12:49 AM
Greg in France's Avatar
I think that would be carburettor float valve not working, or blocked, and thus staying open, so the float bowl overflows.
Old Jul 19, 2022 | 05:51 AM
KarelH's Avatar
Thanks for the advice, today I discovered the hatch scrubber, dented cover. He grinded and also put new oil in the pistons. Gasoline did not flow after starting. Test drive 5 km, return back and the petrol was dripping again. It dripped a little. I'll have to take apart the float.
Old Jul 19, 2022 | 09:32 AM
Bill Mac's Avatar
Check that the float chamber breather to atmosphere is not blocked. Most common cause of overflowing float chambers on SU carbies.
Old Jul 19, 2022 | 10:51 AM
KarelH's Avatar
Thanks Bill, is that the screw?
Old Aug 25, 2022 | 12:57 PM
KarelH's Avatar
Where can I buy a gasket repair kit? Or a new AED? Jaguar XJ6 1974
Old Aug 25, 2022 | 07:47 PM
Andy T.'s Avatar
Everything for SU carbs is available from Burlen Services:
https://burlen.co.uk
Old Aug 26, 2022 | 06:46 AM
Jose's Avatar
also check with Joe Curto in the USA.
www.joecurto.com
Biff Baxter
Jun 24, 2022 01:00 PM
retroren
Oct 18, 2021 06:24 AM
Bob OB
Jul 14, 2013 05:55 PM
tsingtao35
Jun 28, 2010 10:43 PM
monkamah
Jan 28, 2010 10:28 PM
