As the title states, im looking to replace the dinky T handle to a nice round shift knob. Is there any kits available or knobs made specifically for the series 1-3 T handles?
I did mine YEARS ago, welded a bolt with the CORRECT threads for the knob, where the flat top bit was, then filed it neat (I cant weld), and heatshrinked some Black stuff to hide the mess.
Gear knob came from ????? XJ40, XK8, dunno, it was on the floor at work, picked it up and pocketed it. It is Jag ,coz thats where I worked at the time, just not sure which model, and does it really matter??
Outside box thinking, look around, wonders are out there all over the place, gear knobs also.
Its my 85 XJS, same thing as yours, just 2 doors and the REAL engine.
Grants XJS Knob
This is well done. I was considering something custom like yours. I have a beautiful wood dash and would love a nice wood knob to compliment my interior
The late XJS shift lever is what you are looking for, as those cars had a knob instead of the T handle. You're looking for roughly 1994 or later, either 4 or 6 litre.
Thanks for that info. I will see if I can just fit a knob over the existing shifter handle with the capsule knob removed - sourcing a 94-96 shifter then deconstructing it for just a shift lever may be more work.
Geez Exc, it's his car, his taste. You probably wouldn't like the fact that I took all four mufflers and the cat off my '86 so I could hear the backrap either.
