tachometer problem after distributor change?
Old Apr 2, 2008 | 10:49 PM
JagtechOhio's Avatar
Default RE: tachometer problem after distributor change?
Greetings,
I'd have to pull out some old diagrams, but I think the tach feed wire is white with blue and slate tracers. Clean up the wires to the module you removed, and see if you can find it. Make sure the likely candidate has no power going to it with the key on. The right one will make the tach work when you attach it to the negative terminal of the ignition coil.
Old Mar 9, 2015 | 11:48 AM
Harlen19's Avatar
Here is a challenge: I am trying to use a Jaguar XJ6 series 1 tach (because it is 6 cyl) to replace the mechanical tach on my Triumph GT6 (hey who let me in here!).
the tach I have has two electrical contacts on the back; one spade terminal and one bullet terminal. Hooking either one to the negative terminal of the distributor, the other to ground, doesnt work. Is there a sending unit thats supposed to go with this? The tach is a smiths RVC2602. Harlen19
Old Dec 22, 2019 | 07:45 PM
dlpweb's Avatar
OK, idiot question for the night
A member suggested looking up several old threads about "relocating amp"
I've tried every combination of words, spaces, commas & plus signs and apparently am too stupid to figure out how to search.
Anyone feeling charitable & wanna explain?
Old Dec 22, 2019 | 08:00 PM
I'm thinking that's not a dumb question at all. I've never heard of such a component in an Xj6 Series car.
Old Dec 22, 2019 | 09:36 PM
Doug's Avatar
Ignition amp?
Where do you want to move it, and why? Move it to a cooler location, presumably?
What year and engine?
Old Dec 23, 2019 | 02:53 AM
OK, idiot question for the night .....
I see all your other posts are in the E-Type forum. Is this question related to another Jaguar you have or posted in the wrong forum?
Old Dec 25, 2019 | 10:39 PM
dlpweb's Avatar
oops
wrong forum
Thanks Graham for the heads up
rsq911
Oct 21, 2018 11:14 AM
afterburner1
Feb 28, 2017 12:20 PM
dcarr
May 17, 2016 10:36 PM
03impala9c1
Feb 17, 2014 04:23 PM
Daimler
Jun 14, 2013 06:05 PM
