tip on removing the starter on a 1987 xj6
Old Aug 14, 2021 | 06:34 PM
retroren's Avatar
Default tip on removing the starter on a 1987 xj6
i didn't have the appropriate ratchet setup to remove the lower starter securing bolt. it's quite a tight fit. i remembered that i had a 9/16 wrench that i cut in half for another auto repair years ago so that along with a pipe and a bottle jack and i was able to use the weight of the car to my advantage. well i know many of you probably would have loosened the bolt easier ways but hey, i never claimed to be very smart just persistent
Old Aug 15, 2021 | 01:48 AM
LT1 jaguar's Avatar
Active Streak: 60 Days
Usually, things that are a mother require some kind of invention.
Dave
Old Aug 15, 2021 | 12:00 PM
retroren's Avatar
funny you should use the same word i did, mother, except i followed it with another word. repeatedly.
Old Aug 28, 2021 | 07:58 PM
Tonytonem's Avatar
Just installed my Bosch starter last month, SAME problem. Wound up using a 3/8 drive, 8” extension. That will have your ratchet back there in transmission land. Remove the metal clip securing the transmission breather pipe(?) and move it out of the way. Then, begin the ratchet action. Worked fine.
Old Aug 29, 2021 | 12:59 PM
retroren's Avatar
Toneytonem: thanks for the tip. i'll give it a try just for practice on the chance my rebuilt stater fails. ren
Old Aug 29, 2021 | 02:58 PM
Jose's Avatar
did you pay a lot to rebuild the starter? you could have instead replaced it with the High Torque starters now being used. Very light and easier to install.
Old Aug 29, 2021 | 04:05 PM
Tonytonem's Avatar
Not sure if that was a question for me, but RockAuto-$60 Bosch(reman.)SR191X. My 1984 XJ6 starts in a bout 1 second. Heavy as heck.
Old Sep 1, 2021 | 05:57 AM
metalbasher's Avatar
Use a 12" extension with a u-joint to get both starter bolts. Works on an E-type too.
mx468
Apr 16, 2018 08:48 AM
Pura Vida
Jan 16, 2012 03:42 PM
wnlewis
Jun 14, 2009 06:42 PM
RickSku
Apr 8, 2008 08:07 PM
