Troubleshooting?
My series 3 4.2 is not getting fuel. Mechanic told me it needed an ecu. Got one, still nothing. Fuel pump seems to he working fine. Wondering if its an injector problem. That being said I cant even get the car to fire off with starting fluid or carb cleaner at all. Just cranks and cranks. Any ideas?
Why the fuel focus? ECU swapped, fuel pump running, doesn't start with spray injection. I guess you could check for fuel pressure at injectors but everything you have said so far would steer me more towards spark (assuming this is a working car that just stopped)
It does have spark, even pulled the plug out and tested. Got it to fire with carb cleaner after messing with it a bit. Still not getting fuel to engine though.
Fuel related possibilities: Screen on the end of the fuel pickup tube in the tank is plugged with rust/crud. Large filter on outlet side of pump is plugged. Pump runs (?) but is worn out or inlet plugged with rust/crud. Fuel pressure regulator is stuck open. I don't have a Jaguar engine so I can't tell you where it is exactly, but it will be where the return fuel line and the fuel rail feeding all the injectors come together. If there is a Schrader valve in that line, that is where you would screw on an fuel pressure gauge and see what you have when the pump is running.
You haven't said what the recent history of the car has been. When was the last time the engine ran normally? What has happened since that time? The only relay I can think of is the one that actually runs the pump when the key is turned. If your pump runs, then that relay is working.
Dave
Dave
Dave
Dave
I will definitely check those options out. Car ran back in september, was driving it on a 300 mile trip home when the battery dies due to the alternator being bad. After getting the battery charged up I couldnt get it to fire again. After messing with it I brought it to a mechanic. They messed around with it for 6 weeks before giving up as they couldn’t locate the problem. The car does have 2 new gas tanks so I dont think the lines got clogged from the tank at all. Thank you for the help though, will definitely check those out tomorrow.
My son had a similar problem in his S3 XJ6. The pump was running but the engine would not start. Checked with starter fluid and it fired up OK
I cracked a fuel line and there was no pressure. It turned out that the electric motor was running but the drive to the pump section had internally sheared
Suggest you check for fuel pressure
scottatl
Aug 12, 2018 09:12 AM
Gustafh
Jul 25, 2017 08:57 AM
