Twin fuel tanks Series II
Old Sep 22, 2019 | 03:03 AM
Crackerbuzz's Avatar
Default Twin fuel tanks Series II
Hello all...
has anyone one attempted or succeeded in linking both fuel tanks together with a central surge tank and feeding their engines from a single pump?
i believe I have a method to achieve this but thought I would check first to see what has been done in the past.
all info appreciated
cheers
craig
Old Sep 22, 2019 | 09:38 AM
Yes, Craig, my car came to me with the tanks T'd together just forward of the right tank (looks factory to me). OEM pumps are still in the tanks for their anti-backflow valves.
An external fuel pump draws from both tanks more or less equally. Tank selection switch only switches the tank senders as the pumps were disconnected and are without power.
Old Sep 22, 2019 | 01:17 PM
Awesome thanks.
can you explain the anti backflow and what it does?
cheers
Old Sep 23, 2019 | 09:29 AM
For my car, the anti-backflow valves, part of the OEM in-tank fuel pumps, keep the gas it its own tank rather than sort of self-leveling. Or, when parked on a side-hill, prevents all the gas running to the low side tank and running out on the ground (seriously frowned upon in these parts).
I think originally their function was to force gas to the engine rather than into the other tank. I'm sure most of not all in-tank fuel pumps have this valve, to keep fuel from draining back to the tank when the engine is stopped.
olivermarks
Dec 23, 2024 02:14 PM
Mattandbec1
May 2, 2020 02:04 PM
o1xjr
Feb 27, 2014 06:52 AM
Undertaker
Feb 24, 2014 01:19 AM
alabbasi
Nov 17, 2013 03:28 AM
