Universal joints
Old Feb 17, 2016 | 05:48 AM
NathanDD6's Avatar
Default Universal joints
Hi all
Just a quick one, I've been under the rear of my car, and having seen all the grease nipples, checked the universal joints.
I found that the one on the propshaft going into the diff didn't have a grease nipple, but the 2 coming out that go to the wheels, did have.
Is this correct, or am I missing something?
Old Feb 17, 2016 | 06:02 AM
Nope.
Some do, some dont. Probably been replaced at some stage with a sealed unit.
Up near the trans will be another, near the centre bearing, and at the rear of the trans.
These are a PAIN to get at. MEMORY, HA, the metal shield has to come off to get at them, and I have a recolection of drilling a large hole in that pan so I could get at those joints without dismantling half the bloody car.
Old Feb 17, 2016 | 09:57 AM
anjum's Avatar
Good point. Will have to remember that later or just get sealed UJs.
Old Feb 17, 2016 | 11:40 AM
NathanDD6's Avatar
Thanks Grant, am I correct in assuming that the sealed UJ's are "maintenance free"?
Old Feb 17, 2016 | 06:15 PM
Correct.
They were all you get as replacements, some many years ago, now they are all turning up with grease nipples again, something went wrong with the "sealed for life" as we all know.
The joints on the prop shaft itself have very little angular movement, the rear cradle is attached to the car, and they will last a very long time either with or without greasing provision.
The half shaft, work hard, so a squirt twice a year is a good thing.
Old Feb 18, 2016 | 04:48 AM
NathanDD6's Avatar
Many thanks Grant, I'll see to it.
Old Feb 18, 2016 | 06:52 AM
alynmurray's Avatar
Should be a nipple at each end of each half shaft as well as one at the bottom of each hub carrier. Sometimes these on the carrier are missing. Also there are plugs that cover the wheel bearings , remove the rubber plugs to grease.
Old Feb 21, 2016 | 02:30 AM
NathanDD6's Avatar
Thanks alynmurrsy. Had a shot at the UJ's yesterday, didn't get much in... Usual I assume? Must be small clearances?
Old Feb 21, 2016 | 09:54 AM
Hmm.......
When I last greased all Nix's joints I neglected the outer half shafts - outta sight, outta mind as they still have the bell guards on.
I suppose before I get seriously on the road I had better address that little oversight.
Eratostenes
Mar 21, 2017 04:00 AM
Delta088
Mar 8, 2016 11:17 PM
Alastair Else
Feb 13, 2016 02:29 PM
blindside
Feb 12, 2016 02:20 PM
cacamp
Feb 11, 2016 08:22 PM
