Valve Cover xj6
Subscribe
Apr 1, 2009 | 01:39 PM
My valve cover has a crack and it oozing quite a bit of oil...how can i repair this. I tried looking for a replacement but i see no such item anywhere. Any ideas how or where i can fix this?
Reply 0
Apr 1, 2009 | 01:43 PM
I have good used cam covers cheap, PM me with year and which side you need if you are interested.
Reply 0
Apr 1, 2009 | 01:58 PM
Its magnesium, and aluminum so dont try welding it. Just buy another from jag tech. I just sanded and painted mine last weekend. How did you managed to crack it. I stood on mine and im 200#..
Reply 0
Apr 1, 2009 | 02:58 PM
Hey Brute,
Thanks for the infomercial! I'm thinking he has a Series III XJ6 4.2: I use 100 inch pounds on those, the aluminum cover is not supported on the underside so it splits between bolt holes when guys crank on them.
Reply 0
Apr 1, 2009 | 04:03 PM
Well since my crystal ball broke, i assumed 95-97, and we all know what *** u me gets you
Reply 0
Apr 1, 2009 | 04:12 PM
i thought it made an edit to the post.... but its a 1986 XJ6 VDP Drivers side Valve cover...for a temp fix can JBweld be used?
Reply 0
Apr 1, 2009 | 05:23 PM
That's up to you, $35.00 gets you a cover (cracks not included) and includes shipping to any U.S. address. I have never used JB weld, how much does it cost?
Reply 0
Apr 1, 2009 | 05:48 PM
Jagtech is right, at the best JB weld would be a temporary fix. It'd probably stick though, at least until you could get a new one. Just do it on the top side, so when it comes loose it doesn't fall into the engine.
David
EverydayXJ
Reply 0
Apr 1, 2009 | 05:52 PM
When I came across a classified ad, written by an owner who was looking for a good Series III transmission, I posted you a message to see if you could help him out. This is what I get as thanks in return. Perhaps we should both consider these as mistakes we won't make again.
Reply 0
Apr 1, 2009 | 06:03 PM
OK, fixed it, no harm done.....
What message? None in MY inbox..
However, personal correspondance via PM would be appreciated, or direct email....
david@everydayxj.com
David
Reply 0
Apr 1, 2009 | 06:06 PM
I posted it in public, probably here during some thread where you and Jose were busy splitting hairs over something. The guy had a JagLovers ad posted, maybe six weeks ago.
Reply 0
Apr 1, 2009 | 06:40 PM
Thanks for that ... no correspondance from him, and nothing showing up in the archives of either site.... I had no idea.
I've sent a message via private email, where the personal conflicts should be discussed....
David
EverydayXJ
Reply 0
Apr 2, 2009 | 06:59 AM
I don't recall splitting hairs with David over anything ?
Jose
Reply 0
Apr 2, 2009 | 09:57 AM
Anyway...back to the Valve Cover...
Once upon a time, I had a Ford 302 with cast aluminum valve covers that I over-torqued. JBwelded the inside and outside, sanded down the JB inside smooth and it never cracked or leaked again...would still recommend a new cover though. JBweld is pretty low budget stuff and works well in a pinch, but would look like crap on your Jag cover.
I also know a guy who used JB on SBC blocks when rebuilding them...never had a problem, but then again, he knew what he was doing-where you can and cannot apply it to.
Reply 0
Apr 3, 2009 | 04:29 PM
How about a shiny chrome or polished alumin. one?
Other old Jag straight sixes have beautiful valve covers. Anything like that for a 1982 xj6 with a 4.2?
Reply 0
Apr 3, 2009 | 06:27 PM
I have been told that the heat of the 4.2 will turn the polished aluminum valve covers of the 3.8 engine into a purple-blue color. I haven't tried. A mechanic told me that.
Reply 0
Subscribe
Currently Active Users (1)
