What is this, and why does it look like this?
Old Sep 19, 2011 | 07:29 PM
Benhamtroll's Avatar
Default What is this, and why does it look like this?
Okay, so I've begun the tear-down on the cylinder head in my 84 XJ6. I'm just about ready to pull the head itself, despite the fact that the bottom middle bolts on the exhaust manifold were designed so that you can't get a socket in there . . .
Anyway, As I was disconnecting hoses and wires and so on, I discovered this:
I'm not 100% certain what this is. It looks a lot like the fuel cooler, but is obviously not. It had a hose connecting it to a box on the back of the alternator. At first I thought it was just clogged, but it actually seems to be welded. Is this correct, or do I have something seriously wrong?
Thanks!
Old Sep 19, 2011 | 07:39 PM
Doug's Avatar
That's the air injection pipe. There should be a hose and a check valve there. The check valve probably failed, causing the meltdown.
The hose goes to the diverter valve on the back of the air injection pump...not the alternator
Old Sep 19, 2011 | 07:48 PM
Doug's Avatar
Here's a pic of my old Ser III. It gives a partial view of what you should have
Attached Thumbnails What is this, and why does it look like this?-jag-xj6-002-2-.jpg
Old Sep 19, 2011 | 07:58 PM
So, this is the offending part?
I'd already removed the short hose piece connecting it to the pipe. I'm assuming this is something I really should get fixed as well.
And your engine is disgustingly clean. Thank you for making me feel inferior . . .
Old Sep 19, 2011 | 08:21 PM
Although, if I don't need to worry about passing emission, does it matter?
Old Sep 19, 2011 | 11:25 PM
Doug's Avatar
On closer examination it looks like the pipe has been intentionally plugged, Yes ?
Anyhow, the engine doesn't mind if the system is removed or defeated so, since you don't have emission testing, I wouldn't give the matter another thought
Old Sep 20, 2011 | 09:13 AM
Thanks again. You are, as always, a life saver. :-)
Old Sep 20, 2011 | 04:26 PM
sparkenzap's Avatar
But he does make us all feel inferior, does he not?
Old Sep 20, 2011 | 05:00 PM
Doug's Avatar
Never my intention
Old Sep 21, 2011 | 04:28 PM
Don't worry, Doug. We all need someone to look up to! ;-)
