Wiper dont work, xj12 s3,
Hi,
I dont get wipers to work, totally dead.
No power (electricy) to the wipermotor.
I have check the switch.
I get no power om the fuse either, should it not be +12v there?
Where can I find the relay?
Any tips so i can get it to work?
Thanks.
/Mats from Stockholm
Thanks.
there is a blue relay located in the passenger side, under the dash, behind the fuse box but that relay is only for the intermittent function of the wipers, .(switch arm all the way down or by pulling the switch stalk arm towards the rear for a single wipe).
you can download the S57 guide in my website.
Power to the fuse comes from the Ignition load relay. This relay also sends power to fuse #5. If fuse #5 also lacks power, then the relay is suspect.
I think you are on the right way Doug.
I am at the work just now, but i think there is no power on fuse 5 either.
I will try to find that relay, I have find info in another tread here in the forum and what I can see there is a "standard" relay like this?
I hope that will fix my proplem.
/Matte, Sweden
/Matte, Sweden
chad3609
May 31, 2009 12:05 AM
chad3609
Dec 15, 2008 05:06 PM
chad3609
Dec 13, 2008 10:17 PM
