wiper motor
Old May 22, 2015 | 06:45 AM
amaezing's Avatar
Default wiper motor
it's such a relief to have my ride running right. almost 500 miles in the last two days, and just awesome.
my wipers don't return home when you turn them off. Is this common? is there an easy fix? It's not a big deal, but it is a bit annoying.
Old May 22, 2015 | 07:22 AM
Doug's Avatar
The most common fault is the switch itself. Easy-ish to replace.
There is also a 'park' switch on the motor but they don't seem to fail very often.
As for the switch ....it might be repairable. I fixed one once, years ago, using instructions found online from a Jag outfit. I've long forgotten the details and the web page has been gone for years....but perhaps someone here remembers.
Old May 22, 2015 | 07:26 AM
Jose's Avatar
it could be the wiper switch at the steering column, or the park switch at the wiper motor.
I would start checking at the wiper switch at the steering column. Worn contacts inside the switch case will cause this symptom.
Page 84-1 of the Electrical Section / factory service manual, shows you how to remove the switch.
Old May 22, 2015 | 07:34 AM
Jose's Avatar
Originally Posted by Doug
As for the switch ....it might be repairable. I fixed one once, years ago, using instructions found online from a Jag outfit. I've long forgotten the details and the web page has been gone for years....but perhaps someone here remembers. Cheers DD
I have a 2006 Newsletter from the Music City (Nashville) Jaguar Club. where it shows how to rebuild the switch.
File Type: pdf
Old May 22, 2015 | 08:52 AM
amaezing's Avatar
Thank You very much. Have to love technology. I definately remember trying to figure things out when all there was, was the people you know. that wasn't helpful in alot of cases.
Old May 22, 2015 | 08:56 AM
Doug's Avatar
'Tis that shim glued to the inside of the case that is they key element of the repair.
Old May 22, 2015 | 01:17 PM
Giovanni LiCalsi's Avatar
The internal wiper switch can be converted from brush type to brushless.
The brushless switch gives you a lifetime of switching.
Old May 22, 2015 | 02:32 PM
Jose's Avatar
post pictures of the conversion, I have never heard of that one.
Old May 22, 2015 | 02:34 PM
Jose's Avatar
'Tis that shim glued to the inside of the case that is they key element of the repair. Cheers DD
an old credit card has the right thickness.
Old May 22, 2015 | 04:04 PM
If someone can post the internal switch parts, I can tell you how to do it.
I have done other brushed switch conversions, for non-automotive brushed switches. It's easy to do. Brushless switches are good for up to 50,000 movements.
Brushless switches come in several styles, sliding and rotary.
Old May 22, 2015 | 08:41 PM
Jose's Avatar
here's a wiper motor imploded. The brushes are the piece with three wires/connectors.
Old May 22, 2015 | 09:22 PM
The steering column switch is what I'm referring to.
Old May 23, 2015 | 05:59 AM
Jose's Avatar
the switch has no brushes, only brass contacts
Old May 23, 2015 | 12:19 PM
Hope to see the interior of the switch.
I'm curious about upgrading....
kingdom worker
Nov 14, 2020 03:47 PM
Ferdie
Nov 26, 2018 05:42 AM
SCMike
Nov 25, 2015 07:55 AM
davidboger
Oct 1, 2015 10:13 AM
