Worn steering rack?
Old Sep 21, 2021 | 08:32 AM
redtriangle's Avatar
Default Worn steering rack?
Hi guys,
Today I tried to do a "toe" adjustment on the Series 1, after finally getting the castor and camber settings to my liking.
With the front wheels on slip plates, I noticed slight movement in each front wheel, when grabbing @ the 9 & 3 o'clock positions and rocking back & forth.
The steering rack was centralised and "locked" in position as per the factory manual instructions. Wheel bearings are fine with no measurable play.
Given toe-in is specified at 1.6 to 3.2 mm, probably a lot less than the above detected movement, I now figure I'm wasting my time.
Please tell me I'm not due for a rack replacement
Old Sep 21, 2021 | 08:46 AM
I doubt it.
If the rack is locked with the pin in the hole, then the rack innards are locked.
I suspect:
rack bushes,
tie rod ends,
or rack ends themselves.
Nothing else moves with that pin inserted.
Old Sep 21, 2021 | 08:53 AM
Jose's Avatar
tie rods. Replace them.
Old Sep 21, 2021 | 09:04 AM
As Jose says, start with the easiest thing first. If that doesn't work, you can always get more complex and expensive later.
Old Sep 22, 2021 | 12:53 AM
Greg in France's Avatar
If you get a helper to do the rocking, you should be able to see, or at least feel, where the movement is.
Old Sep 22, 2021 | 06:18 AM
Thanks everyone. I'll get the missus to do the rocking, once all the housework's done.
(Ducks for cover)
Pete
Old Sep 22, 2021 | 07:56 AM
I've used the tried & trusted "string" method for checking my toe.
Easy as, if you have a lift/hoist.
I welded captive nuts to the ramps, so the posts (adjustable) just bolt on.
Old Sep 23, 2021 | 07:36 AM
iramphal's Avatar
Had a problem identical to this on a Honda civic. Changed the tie rods to no avail.. Turned out to be the inner tie rod that was worn. Special wrench to remove that inner nut!
Old Sep 23, 2021 | 12:58 PM
Jose's Avatar
replacing the INNER tie rods in a rack is no big deal, you can rent the special tool at Autozone, O'Reilly Auto Parts, Advance Auto Parts, etc.
Here's a good demonstration:
Old Sep 24, 2021 | 09:11 AM
I'm wondering Where he got a new tie rod end that wasn't Pre-lubed and came with hole for grease fitting!
Old Sep 24, 2021 | 09:44 AM
Jose's Avatar
I was wondering where he got the INNER tie rods Elinor.
Old Sep 24, 2021 | 10:27 AM
That was no mystery to me, Jose, we changed the Inners on Nix's rack when we did all that work in 2014-2015.
I can dig through the File to find the invoice If you're curious.
Old Sep 24, 2021 | 01:28 PM
Jose's Avatar
Elinor my rack is fine, I just did not know that you can get the inner tie rods by themselves.
However if you find the part numbers, you could post them in the HOW TO section, it would sure help everybody in the future. Thanks.
Old Sep 24, 2021 | 09:42 PM
We got the Inner tie rod from O'Reilly, but upon looking up the part number, it seems they no longer carry only that part. The number now refers to a complete rebuilt rack.
DRAT!!
Old Sep 24, 2021 | 11:01 PM
These say they fit, maybe they do!
https://www.ebay.com/itm/27354892195...0AAOSw3ANb40TE
Old Sep 25, 2021 | 03:46 AM
Hi everyone,
This is what I have bought
https://www.ebay.com.au/itm/15243416...m=152434168801
Turns out that, after absorbing the excellent advice from all, I discovered my outer tie rod on the RHS, and inner tie rod of the LHS both have play in them, so for about $200 Ozzie dollars I can completely overhaul both sides. As for Elinor's query, the outers have the greasing valves which is what I prefer too. BTW, the "bible" says they can all be replaced with the rack in situ (thank you God) and the big nut for the inners appears easily accessible, so no special tools required. Thanks Jose for the video anyway.
https://i.ebayimg.com/images/g/jUgAA...E0N/s-l500.jpg
Old Sep 25, 2021 | 04:02 AM
Here is the ebay listing for the inners. Being aftermarket, I guess the part numbers what not mean a lot in other countries.
https://www.ebay.com.au/itm/18445260...gAAOSwqvRfZE0N
Old Sep 26, 2021 | 01:18 PM
JagCad's Avatar
Might be an idea to give her a hand with the house work so she can help you in the shop work???
jagwarman
Nov 30, 2018 06:14 AM
VancouverXJ6
Feb 10, 2018 03:31 AM
bjzwissler
Nov 7, 2016 09:24 PM
sogood
Sep 15, 2015 07:35 AM
NTL1991
XJ40 ( XJ81 )
Sep 4, 2015 06:01 PM
