xj6 gas tank
Old Mar 4, 2013 | 07:11 PM
oem6pak's Avatar
Default xj6 gas tank
ive got an 84 xj6,question is when the tank switch button is pushed in which tank am i running off-the pass or the driver side?
Old Mar 4, 2013 | 08:52 PM
joycesjag's Avatar
oem6pack, I moved your thread over here for better exposer.
Old Mar 4, 2013 | 09:11 PM
Doug's Avatar
I can't remember but someone will come along soon, no doubt.
There are actually a couple arrows on the switch, illuminated by little light bulb, to tell you left or right. Problem is, it's probably burned out and, even if it isn't, the glow is pathetically weak....so you might miss it.
On the side of teh switch there is a white stripe with either and "L" or an "R" written on it. If it isn't worn away it'll be visible only when the button is out.
Old Mar 4, 2013 | 09:40 PM
oem6pak's Avatar
Default gas tank
thanks that helped,when its pushed in its running on the driverside,i needed the lights on to see it.
Old Mar 6, 2013 | 05:24 PM
Cyclehead's Avatar
You got it. Pushed in is LH side tank. I always switch off the LH tank at 150 miles, then run the RH tank until it's empty, then back to the LH tank as "reserve" while I find a gas station.
Old Mar 7, 2013 | 10:27 AM
JagCad's Avatar
Yeah, I learned a lot here and there. For a time, I had a note in the cubby. Left in, right, out!!
Early on in my ownewrship late wife and I were on the way to church early one Sunday morning. In the middle of a busy intersection, the new toy gassped asnd hesitated!!! An epiphany struck me and I tapped the selector ! The trusty jaguar resumed power and we got to church on time. A higher power, no doubt!!
At about that time, we still had the 85 Ford 4x4 pickup. It was blessed with dual tanks. Didn't realize that til the forst time I went to the gas station!! That system allowed a seamless transition as one tank went empty!!
But, too late for Ford to export that expertise to the XJ6 line !
Carl
Old Mar 29, 2013 | 02:21 AM
Pete1's Avatar
Hi Guys
My gas tank on my 77 XJ6 is clogged. I am contemplating removing both tanks, and cleaning them out.
Question is: How do I get them out? Where are they?? I assume they are in the rear fenders?
The reason for my ignorance, is that I have owned the car for only a month now, and am still finding my way around it.
Regards
Peter
Old Mar 29, 2013 | 11:52 AM
JagCad's Avatar
Yes, one in each rear quarter panel But, is it the tanks that are clogged or merely the line?
There are large drain plugs behind the valences that can be reached by removing plugs.
Have a large container to catch the old fuel. Have new o rings and sock filters available.
Open all the lines in the boot and replace the filters and rubber lines. Blow all lines free with compressed air, Tank forward is best.
Clean or replace the pump/s.
A lot of work but simpler and easier than pulling both tanks. And, even if you did, this would be a good idea anyway.
Carl
r r
Old Mar 29, 2013 | 10:28 PM
Ahabiam's Avatar
Honestly its not so hard to pull the tanks. I pulled mine out and had them dipped and coated. i also changed out the sender units for the guage. If you access the panels and remove the large plugs you can flush the tank without too much difficulty as well. Expect to change the internal filters, right above the drain plug housings. If you decide to proceed, send me a message and I can send some pics to get you started.
Old Mar 30, 2013 | 06:01 AM
Pete1's Avatar
Hi.
I've just cleared the lines with compressed air, put in a new fuel pump, and the only way I can get the old bird to fire up, is if I spray "quick start" into the carbs. I think the only thing to do is pull the tanks. I'd love those pics.
petercahi@gmail.com
Old Apr 1, 2013 | 03:41 PM
Ahabiam's Avatar
Pete1 - I sent what I could via G-Mail. Let me know if this helps. Looking at this, I see I labled some of the fuel lines incorrectly. If they do not come across in e-mail - I also loaded them all in my album for restoring the saddle tanks. Good luck.
Attached Thumbnails xj6 gas tank-fastener-location-line-location.jpg   xj6 gas tank-filler-neck-fastener-location.jpg   xj6 gas tank-left-tank-neck-o-ring-location.jpg
GordoCatCar
Jan 2, 2017 01:10 PM
lovemyjag78
Sep 14, 2015 07:42 PM
lovemyjag78
Sep 11, 2015 02:04 PM
alpecsa
Sep 7, 2015 11:55 AM
1100me
Sep 7, 2015 06:26 AM
