1983 XJS v12 to Cummins build
Old Oct 2, 2017 | 11:42 AM
  #121
Jonathan-W's Avatar
Originally Posted by Pud
Well that was the idea, but i went a little overboard today and decided to DELETE EVERYTHING! hahah
the OMG was for I have never seen an XJS so Naked...
Old Oct 3, 2017 | 12:00 PM
  #122
Pud's Avatar
Pud
I wonder if it's legal to run no wipers in Jersey...
Old Oct 3, 2017 | 07:51 PM
  #123
Ranchero50's Avatar
Jersey drivers don't know how to use turn signals, so why not.
Old Oct 3, 2017 | 10:47 PM
  #124
89 Jacobra's Avatar
Active Streak: 30 Days
I believe it's mandatory in all states to have some type of functioning wipers. That being said, a hand operated wiper, I believe is acceptable. I've seen several old hot rods and some British cars that had a single blade on the outside, with a handle on the inside of the windshield to be manually operated. I do believe that is all you have to have. I could be wrong??? But I don't think so. Ask the friendly Policeman and ask him to look up the statute, on it.
89 Jacobra
Old Oct 6, 2017 | 10:09 PM
  #125
Pud's Avatar
Pud
Update!
Unfortunately the linkage on my engine crane piston took a dump, so i got a new 8 ton piston coming in the mail. The whole crane cost me 100$ and was used so im not too miffed about it.
Anyway! Notched the firewall and now the cummins is closer than ever to fitting properly with enough room for belts/radiators/intercooler/fun stuff
Going to go with some rubber lines temporarily going to a dual pass trans cooler until i find someone to make legit 1/2" lines.
triple disc converter came in the mail
waiting on my front crank seal and rear pickup tube to come in so i can test the engine again.
Old Oct 6, 2017 | 10:16 PM
  #126
89 Jacobra's Avatar
I can see the crazy in your eyes!!! But that's a good thing! Way to go, you may make this work yet!
89 Jacobra
Old Oct 8, 2017 | 10:46 PM
  #127
Pud's Avatar
Pud
Haha thanks man
Old Oct 9, 2017 | 09:15 PM
  #128
Pud's Avatar
Pud
Bump with a small update.
Removed the battery holder due to tiny *** battery size and needing to make it bigger for the bigger motor / more amps needed for the starter to overcome the extreme compression of the cummins.
Removed the little sump tank under the battery. Going to just use the large tank for a bit to see how it does.
BEST NEWS EVER --- - -- ~~~~
The main gas tank had nothing in it at all, but the sump tank was full of horrible old bronze colored gas. Smelled horrible. Purged it and removed the entire thing. Removed the sending unit because it was rusty but clean diesel came out of the main tank when i ran it through
Removed the baffle on the filler neck so i can fill up easier
Old Oct 10, 2017 | 01:21 AM
  #129
Greg in France's Avatar
Why not keep the sump tank Pud? It is pretty important to ensure the pump keeps a proper supply on long fast bends!
Old Oct 10, 2017 | 02:47 AM
  #130
Daim's Avatar
I assume he'll be using an intank pump as well as the high pressure pump on the engine. So an intank pump would eliminate the need for the little sump tank...
Old Oct 10, 2017 | 03:41 AM
  #131
Pud's Avatar
Pud
The lift pump on the engine pulls fuel from the tank. I don't need any pumps in the rear from the advice I've been getting on the diesel forums. The sump tank is extremely rusty as well. I question the inside of it.
Old Oct 10, 2017 | 01:31 PM
  #132
Paul_59's Avatar
Banned
Originally Posted by ronbros
almost no one here know what a Cummins 5.9L ,12 valve can do,
make over 800HP BUT over 1500 ftlb. torque, without revin into hi rpm numbers.
I know you're a diesel engine fan Ron, however my information on Cummins 5.9L 12 valve engine is that the most powerful version they produced made 235 bhp 460 ft lbs as standard in turbocharged form.
Are you saying that they can be modified to get over three times the power and torque ?
Old Oct 10, 2017 | 01:43 PM
  #133
Pud
I did not mean you need a pump at the rear. I meant that, as the main tank is very wide, the fuel sloshes to one side on cornering and the main tank central fuel exit pipe gets exposed to air and the fuel pressure drops, with the possibility your diesel injectors get air in them. The sump tank makes a good collection point that is always full of fuel. No reason it cannot be piped directly from there to the engine pump, without needing a pump in the boot (trunk).
Greg
Old Oct 10, 2017 | 09:13 PM
  #134
Pud's Avatar
Pud
I'll try to salvage the sump tank then
Old Oct 10, 2017 | 09:48 PM
  #135
Pud's Avatar
Pud
SO CLOSE.
Need to rip open the trans tunnel a bit more.
Old Oct 11, 2017 | 08:33 AM
  #136
Ranchero50's Avatar
What's fighting with the oil pan? You have a ton of room up front, why not use some of it?
Old Oct 11, 2017 | 09:28 AM
  #137
Pud's Avatar
Pud
The trans tunnel is too narrow for the 47rh.
I want room up front for hoses, rad, fan, and intercooler. Probs trans cooler too
Old Oct 13, 2017 | 07:09 PM
  #138
Pud's Avatar
Pud
Bump. Sealed my front timing cover and my front main seal today.
Old Oct 13, 2017 | 11:26 PM
  #139
89 Jacobra's Avatar
Boy Pud I sure wish you were closer. I just found out when my XJs had the engine fire it also burnt everything under my dash! You can't tell it from the outside but I was going to pull the interior, as I need to do some cutting to clear the headers, and didn't want to set it a fire! To late, it's already toast! So now I'm looking for a Parts car. Damn the Luck.
Old Oct 15, 2017 | 02:37 PM
  #140
Pud's Avatar
Pud
Having issues with transmission clearance still. going to be sawzawlling a lot more once i get more time... wish i had a garage haha
