1988 xjs radiator removel
Old Sep 5, 2018 | 12:17 PM
Shahar Alon's Avatar
Default 1988 xjs radiator removel
hey guys
im tring to remove the radiator so i can change all the water hoses. can anyone help me with the step to do it ?
Old Sep 5, 2018 | 12:31 PM
Greg in France's Avatar
If you are doing all the hoses (all 14) then removing the rad helps a great deal with the crosspipe hoses. If you are just doing the rad top and bottom hoses it does not really help!
To remove the rad:
  • Undo the bleed pipe that runs across the top of the radiator
  • Undo the aircon dryer brackets that also are fixed to the panel above the radiator
  • Undo the four bolts holding this panel (the panel that goes across the top of the radiator is bolted by four bolts two each side)
  • VERY carefully keep all the fixings and note where they all go and the order of washers, copper washers spacers on the breather pipe, which hose goes to where from where, earth wires under fixing bolts etc etc, and take photos.
  • The fan shroud is bolted to the panel above the rad too, and must be undone, and various bits of loom, relays etc etc are also bolted to it and must be undone and pushed carefully out of the way.
  • Undo any other fixings that go through the panel, (eg the condenser top bolts.
  • Now the radtop panel can be removed and the main radiator top hoses and bottom hose removed, and the radiator lifted up and out vertically.
  • If you undo the bonnet struts, the bonnet (hood) can be made more vertical, which helps, prop it with a broom handle or similar, and have a friend hold it while you pull out the radiator.
  • Clean out the radiator fins and those of the aircon condenser and oil cooler which are in front of it.
Old Sep 5, 2018 | 12:49 PM
Default done it but
hey greg
first off all many thanks for your time answering my question.
yesterday i done all of the things you said exept removing the top and buttom hoses of the radiator
mybe its the resion the rad doesnt come out ??
i start this mini project cuz the hose from the buttom rad to the water pump (i think) got explode and i dont have access to replace it.
Old Sep 5, 2018 | 05:12 PM
sidescrollin's Avatar
Yes the hoses need to be removed. If everything else is done the radiator is just resting on pegs on the bottom and just come up and out.
Old Sep 5, 2018 | 05:58 PM
orangeblossom's Avatar
Hi Shahar
Taking off the Bottom Rad Hose can be a bit of a nightmare but if you've got a replacement hose, then one of the ways of getting it off, is to just cut it through with a breadknife
Or else try and wrangle it off with a strap wrench like this one, as the bottom hose very often glues itself on to the Outlet Pipe of the Radiator and then doesn't want to come off
Old Sep 6, 2018 | 12:01 AM
my big issue is to get to the hose that connected to the water pump.
what is the best way doing that ?
Old Sep 6, 2018 | 03:46 AM
Hi Shahar
Once you have disconnected the Bottom Hose from the Rad, then you may be able to break its grip on the Pump by twisting it, or if not then get the Rad out first and then you can use the Strap Wrench on the Pump
Just be very careful not to damage the Rad as they cost a fortune!
Useful to protect it with a piece of Cardboard when lifting it out
Jaguarstyper
Jan 1, 2018 11:34 AM
Muddydog
Exterior
Oct 5, 2014 10:17 PM
brgjag
Sep 6, 2014 09:05 PM
orangeblossom
Mar 30, 2014 05:29 PM
Simprof
Mexico, South America
Oct 14, 2010 07:26 PM
