1989 xjs 5.3 v12
Old Apr 12, 2014 | 08:58 AM
Dave2254's Avatar
Default 1989 xjs 5.3 v12
Hi guys,
Today i brought a lovely XJS V12 but the power steering pump is making a horrible noise when i turn the wheel so suspect it needs replacing. Where is the pump and is it easy to replace?
Any help apritated
Dave
Old Apr 12, 2014 | 09:30 AM
Greg in France's Avatar
Welcome to the fold. The pump is on the front of the engine, on the UK passenger side, about level with the water pump and its pulley is driven by the same belt as the water pump. It has a cap on top with a little dipstick attached to it. The cap is hard to see the first time you look but a torch and looking just behind the pulley will find it. Check the level first, check the belt tightness and perhaps change the fluid before doing anything more drastic?
The pump just unbolts, and apart from access problems (welcome to V12 XJS land) is not in principle hard to change.
Greg
Old Apr 12, 2014 | 10:44 AM
XJSFan's Avatar
Always was curious on how all of you change out/drain the Power steering fluid?
Old Apr 12, 2014 | 10:54 AM
On the V12 undo the high pressure outlet and low pressure return at the back of the pump and drain. This will change 70% at least I guess. If you really want to get more, undo the unions on the rack (easyish on a RHD car).
Greg
Old Apr 12, 2014 | 10:59 AM
Doug's Avatar
A suction pump with the hose in the fluid reservoir will work. Or even a turkey baster.
Or you can remove the return hose from the back of the pump and just let the oil drain. Messy, though ! Of course you'll never get *all* the fluid out. There's still oil in the rack itself and all the pipes and hoses.
Or find the lowest hose/lowest connection in the system, undo it, and let the fluid drain.
Or a combination of methods.
Old Apr 12, 2014 | 11:23 AM
XJSFan's Avatar
I have tried the small hose in the reservoir but it really does not get much out. Not sure I want to remove any PS hoses and make a mess. LOL... Guess I'll just keep taking out a few ounces every few weeks.
Hopefully Dave, that started this thread, only needs to add some ATF/Lucas powering steering fluid to cure his noise.
Old Apr 14, 2014 | 10:41 AM
Dave2254's Avatar
Hi thank you for all your help! I hope i just need to add/change the fluid too! But the noise is quite loud so im suspecting not will keep u guys posted
Old Apr 14, 2014 | 12:09 PM
Flint Ironstag's Avatar
Yeah, check the fluid level first before spending money.
Old Apr 14, 2014 | 01:43 PM
XJSFan's Avatar
I know people that have used Lucas Power Steering fluid to help with noise, seaping and other issues. It does seem to work well...
Old Apr 15, 2014 | 04:22 PM
camcor's Avatar
Welcome, I to am a recent purchaser of an XJS 1985 and had noise and leaking from the power steering unit, the car had been sitting a long time, I used Lucas P S stop leak and with the engine warm went wheel lock to lock about 3 times and it cleared it up. Good Luck
Old Apr 16, 2014 | 03:50 AM
andersh's Avatar
Hi Dave, I'm in Bournemouth too - if you see a white '89 v12 around it's probably me!
Cheers,
Andy
Old Apr 16, 2014 | 05:40 AM
Dave2254's Avatar
Hi thanks for all your help ive put psf in today and the noise has gone!!! :-) thank you all for your help and i will look out for u Andy lol
HypnoGuru
Oct 23, 2018 09:53 AM
Mac Allan
Oct 27, 2015 04:49 AM
vinny jones
Oct 5, 2015 07:20 AM
Regular rick
Sep 24, 2015 08:35 PM
1100me
Sep 7, 2015 06:26 AM
