1989 XJS small red light on console near gear indicator
Old Oct 30, 2017 | 11:39 AM
Andy89XJS's Avatar
Default 1989 XJS small red light on console near gear indicator
Can someone help me understand what this light is for ? Thanks in advance.
Old Oct 30, 2017 | 02:05 PM
Mark SF's Avatar
Sounds to me like you have an aftermarket alarm. I do, and that's where they put the red light to indicate the alarm is armed.
Old Oct 30, 2017 | 03:52 PM
RonaldP's Avatar
In my 95 the factory alarm red light is on the cigarette lighter console plate.
Old Oct 31, 2017 | 02:52 PM
Flint Ironstag's Avatar
This thread...
Old Nov 1, 2017 | 07:58 AM
malc4d's Avatar
From another forum
In reply to a message from jdere sent Sun 4 Sep 2016:
There was an optional dealer installed factory alarm available in 1989. It was installed under the driver's seat and had the ability to lock and un-lock the doors, sound its own horn, flash the lights, and disable starting. A red LED warning light was usually installed on the steering column cover and had a valet switch underneath the column cover, and the system had a backup gel-cell battery - also installed under the driver's seat. The remotes were a nearly square fob with a single white button and a Red LED. There were some variations of the FOB over the years. That basic alarm system was used thru MY 93.5 when the newer alarm system came along. The facelift XJS's, beginning in '92, were pre-wired at the right rear area of the trunk/boot for the newer alarm system to come. The '92 and '93 (to '93.5 which had the optional system installed) used a
Jaguar adapter harness to enable it to use the older alarm system and backup battery - which was then installed in the new location at the right rear area of the trunk/boot.
If the optional system was installed in your '89, you should have the alarm box and battery under the driver's seat. You should also have the Red LED and Valet switch located somewhere on the steering column cover. The flashing red radio light has nothing to do with the alarm system. I don't recall the
function of the radio flashing red LED on the '89, nor what might be causing your horn to sound. Someone else can offer comments on that.--
lockheed 92 XJS Cpe, OB rear brakes, 97 LT1/4L60E
Austin, TX, United States
--Posted using Jag-lovers JagFORUM [forums.jag-lovers.org]-- --Support Jag-lovers - Donate at Moved, please see http://www.jag-lovers.org/donate11.php instead --
Old Nov 1, 2017 | 09:47 AM
Mark SF's Avatar
Originally Posted by Flint Ironstag
This thread...
This post...
Old Jun 13, 2020 | 09:12 PM
metal144's Avatar
Originally Posted by malc4d
From another forum
--Posted using Jag-lovers JagFORUM [forums.jag-lovers.org]-- --Support Jag-lovers - Donate at Moved, please see The Jag-lovers Fundraiser Page Has Moved instead --
Great post
Old Jun 16, 2020 | 02:31 AM
Dukejag's Avatar
Mine is an 89 and has the red light, but no switch on the steering column.
But mine is a right hand conversion when imported from the USA so who knows what happened.
Kodwo Cohen
Jun 10, 2024 03:41 PM
djpxk8
Aug 29, 2021 07:05 PM
orangeblossom
Oct 22, 2017 11:10 AM
JagNoir
Apr 24, 2015 02:35 AM
pdxguy
Sep 22, 2011 03:06 PM
