1990 xj12 Will not start. Help!!
Old Jul 20, 2012 | 10:27 AM
Mike Ian's Avatar
Default 1990 xj12 Will not start. Help!!
HI, I have a 1990 XJS12 Convertible with 19k miles on it. I pulled out of the garage to wash it, since it had been sitting for a while I left it running while washing. After about 20 mins of it running fine I heard is slightly sputter, it straightened out after a couple of seconds then 5 to 10 seconds later It just shut off as if someone turned the key off. Fuel pressure is fine, fuel pump is ok. I put a small shot of starting fluid in the air intake and it fired up for a second or two. Any ideas on what the problem night be?
Old Jul 20, 2012 | 10:42 AM
Doug's Avatar
If it runs on starting spray then you're obviously lacking fuel...which makes me wonder how you determined the fuel pressure and fuel pump are OK
If fuel delivery and pressure are OK that leaves us with injector pulse. Often on Marelli cars the crank sensors die and the injectors won't pulse.....but that's just one possibility.
Do you at least have supply voltage to the injectors? Do you have a test meter or test light?
This really belongs in the "XJS" section
Old Jul 21, 2012 | 09:29 AM
Clamdigger's Avatar
Mike,
If you fire and run on starting fluid, you have a fuel/fuel delivery problem. Check voltage at the injectors to see if they are getting a firing signal. How old is the fuel?
Oh, please don't use the starting fluid again, throw it away.
Old Jul 21, 2012 | 07:43 PM
Lumppy47's Avatar
You might have some water in the gas tank (if the car has sat unused for a few months there will be condensation in there) also when washing the car some water might have entered the tank if the drain at the filler door is plugged up.
sadepol01
16
Nov 22, 2024 05:05 PM
MILOU13
Nov 25, 2015 02:39 AM
gunlocators
Sep 30, 2015 08:05 AM
Mark SF
Sep 28, 2015 01:51 PM
