1993 XJS 4.0 Rear Bearing Rebuild and Tolerances ?
Old Jun 25, 2021 | 08:48 PM
JBRoberts's Avatar
Default 1993 XJS 4.0 Rear Bearing Rebuild and Tolerances ?
Hello…thanks to everyone for help as I have now finished rebuilding the axle stub bearings. I am now finishing up rebuilding the rear wheel bearings in the carrier hub.
I am a bit confused after reading various threads about how to set the bearing tolerances. Here’s my confusion:
1. When I disassembled the halfshafts from the hubs all I had was a bronze/phosphorus washer and a conical spacer - no shims whatsoever
2. I read that if all you are doing is replacing the bearings and races you can reuse the bronze/phosphorus washer and conical spacer, torque the axle shaft nut to 120 ft lbs and I’m done ??
So, I don’t think I need to do any measurements or add shims to make sure I have Zero end float ?
any thoughts or comments would be much appreciated
thanks
JB
Old Jun 25, 2021 | 09:03 PM
motorcarman's Avatar
Use NEW bearings/seals with the old original spacer and shim and go o0n with your life!!!!!!!!!!
Old Jun 25, 2021 | 09:33 PM
JBRoberts's Avatar
Awesome ! That’s what I have done and torqued the axle nuts to 120 lb ft. ….much easier than shimming etc
thanks soooo much
JB
Old Jun 26, 2021 | 11:14 AM
Jaguar already did all the hard work of setting up that particular hub.
A fresh cast hub and new bearings require a painstaking procedure to get the bearing preload correct.
I prefer to let the factory do it when it is assembled. Bearing tolerances are tight so no discernible difference should be noted with a simple bearing relube or replacement.
nakuttaja
May 29, 2020 12:37 PM
bigbore
Apr 14, 2015 04:05 PM
RagJag
Aug 10, 2014 11:59 AM
JagScott
Nov 28, 2010 06:51 PM
bhmaxjag
Mar 16, 2009 10:32 AM
