1994 xjs will not accel without pumping fuel pedal
Old Mar 7, 2013 | 10:46 AM
Icarrya45's Avatar
Default 1994 xjs will not accel without pumping fuel pedal
Any help would be appreciated. My 1994 Xjs convertible idles fair (small miss), however , it will not accel with a load. It revs up with no load and sounds smooth as a sewing machine, but put it in gear and try to accel falls on its face. will move if you do not touch accelerator. It has new temp censor, new fuel filter, and throttle position censor.
Old Mar 7, 2013 | 01:00 PM
Oddrods's Avatar
Which Motor?
If it is the V12 then it probably has one of the coils out causing it to run as a 6 cyl. It will behave as you described but it is very dangerous to drive as it will more than likely catch fire from what I have read.
Old Mar 7, 2013 | 03:24 PM
calvindoesntknow's Avatar
check your TPS. ive had a mitsubishi do the same thing because it would only read idle and WOT
Old Mar 7, 2013 | 07:30 PM
Icarrya45's Avatar
Thanks, it has the 6cyl. Arrrrrrg!! this is my first Jag. Father-in-law gave it to me after sitting for 5-6 yrs.
thanks again for all the help
dsnyder586
Dec 29, 2024 07:39 PM
1100me
Jul 24, 2023 06:10 PM
hen555
Sep 7, 2015 11:13 PM
1100me
Sep 7, 2015 06:26 AM
d a
Sep 3, 2015 02:34 AM
