5.3 V12 takes a while to start...
Old Oct 9, 2020 | 04:26 AM
lambo911's Avatar
Default 5.3 V12 takes a while to start...
Hi all,
I have a 1993 5.3 V12.
Recently it has needed a fair bit of cranking before it kicks into life, especially if it has not been started for a while.
It just whirs away for maybe 20-30 seconds then starts up.
Feels like there is no fuel.
Any ideas?
Richard
Old Oct 9, 2020 | 05:28 AM
orangeblossom's Avatar
Hi Richard
Maybe the Fuel Filter is Blocked and needs replacing, less than a Tenner on ebay, so that is what I would do first, as its sounds like fuel starvation could be the problem
Old Oct 9, 2020 | 08:21 AM
Doug's Avatar
Continuing with the 'no fuel' thoughts......
Turn the key 'on' without trying to start the engine. You should hear the fuel pump hum for 2-3 seconds. This primes the fuel rail at the engine.
Do you?
Next (and assuming you hear the hum), turn the key 'on', smartly jab the throttle a couple time, and then turn the key to 'start'. Any difference? The throttle jab should energize the fuel injectors, thus giving squirt of raw fuel into the cylinders. If this improves the situation then it sorta confirms a lack-of-fuel problem.
Also, when you change the fuel filter, empty the contents into a clear container. What you see might dictate your next steps.
Old Oct 9, 2020 | 08:52 AM
lambo911's Avatar
Do you?
Hi, I just tried what you suggested.
Turn ignition on - yes I could hear the fuel pump prime
Jabbed the throttle a couple of times
Tried to start it... no was the same just turned over quite a bit before it started
Old Oct 9, 2020 | 10:44 AM
Greg in France's Avatar
Verify that you have spark during the starter-churning phase.
Old Oct 10, 2020 | 05:26 AM
lambo911's Avatar
Hi,
There was no spark! Then started to spark and it started.
The spark looked quite weak
Old Oct 10, 2020 | 06:01 AM
Hi Lambo911
Test the Spark on Both Banks and see if the Spark on one Bank is better than the other
That might narrow things down a little bit
Old Oct 11, 2020 | 10:40 AM
lambo911's Avatar
I have found that the battery voltage has an influence..
The engine was turning over ok but the voltmeter was half way between 9 and 13
So I fully charged the battery and it fired up straight away.
My car has the two ignition amplifier units mounted on the front panel.
A while ago I was doing some work on the AC and I unplugged the front ignition coil. I forgot to reconnect it, started it up (started fine) and drove a few yards before realising something was up and the engine light also came on. I reconnected it and all was ok, but I think it is since then I have had this starting issue.
I wonder if running the engine with the coil disconnected damaged something ?
ronbros
Nov 1, 2023 09:15 AM
Alphatrev
Jul 7, 2021 10:11 AM
yelton
XJ XJ12 ( X305 )
Jun 3, 2020 04:54 AM
FastCat85
Nov 25, 2015 06:38 PM
velder
Jul 6, 2011 01:28 PM
