6.7L V12 build
Old Jun 9, 2017 | 05:37 PM
  #281
ronbros's Avatar
Originally Posted by xjsv12
They did change the tappet (follower), tappet shim , valve collar and the valve . It was reduced weight.
again nice find xjsv12; yes with less weight you would need less spring rate.
could also help with available parts bin(cost).
Old Jun 9, 2017 | 07:50 PM
  #282
warrjon's Avatar
Originally Posted by warrjon
What about the springs are they lighter in the 6.0L for lighter valve train?
Doh I'm stupid sometimes I have a 5.3L HE in the shed, I'll pull a set of valves out and measure the valve spring rate.
Old Jun 10, 2017 | 02:55 PM
  #283
ronbros's Avatar
good idea warrjon, also measure spring free length and spring diameter?
Old Jun 14, 2017 | 05:39 PM
  #284
warrjon's Avatar
I went to flow the spare 5.3L head I have which has no studs in the head so I pulled a stud from my 6.0L head, needed to hold the valve opener.
Gotta Love Jaguar/Ford, the cam carrier studs in the 6.0L are M8 and in the 5.3L 5/16UNC
Old Jun 18, 2017 | 03:06 AM
  #285
warrjon's Avatar
The new Exh valves are square on the margin where the originals have a very generous radius.
Original valve
New Valve
New valve modified
Old Jun 18, 2017 | 10:28 AM
  #286
ronbros's Avatar
it may help exhaust flow get started into port!
also eliminate a potential hot spot.donno.
who made the valves , any possibility of actual material?
Old Jun 18, 2017 | 05:02 PM
  #287
warrjon's Avatar
Don't know who made the valves, Norm sourced them
Old Jun 19, 2017 | 05:50 PM
  #288
xjsv12's Avatar
The main supplier was AE. They were pistons, rings, valves, valve guides, chain. Vandervell made shell bearings. Then the TRW produced guides and valves.
AE made replacement STD and oversize shell bearings
Old Jun 28, 2017 | 02:41 PM
  #289
Jonathan-W's Avatar
did you get to flow test the 5.3 heads?
Old Jun 28, 2017 | 04:41 PM
  #290
warrjon's Avatar
No because the head stud thread was UNC and the 6.0L is metric and I didn't have UNC studs to mount the valve opener to so I could not flow it.
Old Jul 2, 2017 | 03:37 PM
  #291
FerrariGuy's Avatar
Just FYI, in case you hadn't noticed, Mark Eaton on Jag-Lovers did some CFD modeling of the various V12 ports coming up with some interesting numbers and simulations.
https://forums.jag-lovers.com/t/engi...nt-inlet-ports
Paul Kobres
Old Jul 2, 2017 | 05:29 PM
  #292
warrjon's Avatar
Thanks Paul, I have read that thread.
I'm lucky as I have Norm helping me build my engine. The engine is being built for torque not peak HP and will be using stock valve train, I built my own flow bench and have optimised the port for the valve train.
I have a head on my shed floor Norm loaned me which is off a 6.0L V12 out of a Hydroplane and made 615hp, the ports on this engine are small (about 35mm) with very large intake valve.
Old Jul 3, 2017 | 01:04 AM
  #293
warrjon's Avatar
Unfortunately All the pics I had in most threads were hosted on PhotoBucket, PB's decision to now charge $400USD a year for this service made ALL photos past no longer available to view. So I have deleted my PB account
Old Jul 3, 2017 | 02:51 AM
  #294
FerrariGuy's Avatar
Yeah.. I was opening each pick in a new tab, then reloading the main forum page which allowed all of them to properly load. Any chance you might find time to upload them to a different site and edit your posts so that the pics might be available for posterity? I'm looking forward to hearing how the engine performs, you've cut the ports in a way that I suggested on Jag-Lovers many years ago and I'm very hopeful that you get great results from reshaping that seemed instinctual to me.
I agree, a *sporty* XJS driver doesn't need more than the high 300 to mid-high 400 HP range.
Paul Kobres
Old Jul 3, 2017 | 04:39 AM
  #295
warrjon's Avatar
Unfortunately I can not edit old posts to update the pics. Oh well
I am lucky to have Norman Lutz building my engine, from the simulation he gave me I should have around 400-450hp.
I drove my brothers Mustang GT500 before it was detuned as it had too much power for registration around 700hp, it was difficult to drive, even now with around 550hp it's still a handful especially in the wet.
My plan is to re-install the 2.88 diff to aid in traction, the simulation/experience I should have around 500ftlb's
Old Jul 4, 2017 | 08:37 PM
  #296
LongJohn's Avatar
Warren how's your engine coming along?
I think but maybe imagining that you mentioned a centrifugal supercharger somewhere on this forum. Why did you not choose that route?
Also if you are using a later 6L engine are you bound by stricter emission requirements?
I hope don't mind the questions. John.
Old Jul 4, 2017 | 09:34 PM
  #297
warrjon's Avatar
No don't mind the questions at all.
I'm taking the heads to Norm on Saturday, I've decided to use the head guy he uses. When they're done I'll pick them up and CC the chambers. BTW it's a 3hr dive each way.
I was originally looking at supercharging, but the government changed the goal posts and FI on an engine over 3.0L requires a lot of engineering (read huge expense) unless the model had the engine as an option. My brother has a 1967 Shelby GT500 (genuine) he rest-modded it with rack and pinion steering and coil overs, all supplied by Shelby including the engine rebuild of around 700hp, it cost him nearly $30,000 to have the car engineered. He had to rent a race track for the engineer to do brake testing.
The 6.7L will have a lot of torque estimate around 500ftlb's and around 400hp, more than enough for a spirited fang around the back roads near where I live.
Old Jul 4, 2017 | 10:04 PM
  #298
warrjon's Avatar
New exhaust valves
Left is the original valve, Middle is the new valve and right is my modified valve with radius on margin
Old Jul 4, 2017 | 10:21 PM
  #299
LongJohn's Avatar
Warren thanks for the response. Looking at VSB14 the "recommended" max engine capacity is 3 x the manufacturers weight in kg. So 3 x 1825 = 5475cc which should make a supercharged 5.3 ok. In theory anyhow and possibly NA maybe a better option when looking for reasonable outputs.
How are emissions handled on a modified engine? Are the standards you need to meet based on the age of the car or engine?
I'm looking forward to see your results.
Old Jul 4, 2017 | 10:40 PM
  #300
warrjon's Avatar
In VSB14 any modification that increases power more than 20% must be approved by a VASS signatory, this is where it gets expensive, I'll be registering my car as a 6.0L which was optional in 1989.
The car has to meet emission standards for the year it was complianced here so 1990 for me. But we do not have annual Road worthy inspections in the state I live and emission testing is not part of a RW even if needed.
