88 XJSC Factory Oil Filter Discontinued?
Old Jun 9, 2015 | 07:10 AM
Coop613's Avatar
Default 88 XJSC Factory Oil Filter Discontinued?
I called the local Jaguar dealer about getting an oil filter so I can do an oil change on my 88 XJSC and they told me the oil filter was discontinued. Does anyone know if this is true? If so, any suggestions for a good aftermarket brand??
Old Jun 9, 2015 | 07:18 AM
o1xjr's Avatar
If the filter for your 88' is the same as the 85' model here is a list of filters available, search the brands and part numbers on ebay and it should throw up some in your region.
Originally Posted by o1xjr
Ryco Z133, $38. Repco or Supercheap Auto (pre order) or $38(free post) on ebay
Jagdaim EBC9658/L $15 + $15.90 Postage
Framm PH2995A $20 + $8.25 postage . Preston Paige Classics(ebay)
Mann W930/13 $32.10 (free post) Micksgarage,Australia. ebay
Coopers Fiamm FT5925 / old Z509A/ Newest part no WZ133 $36.95 (free post)
motoparts_au (ebay)
Baldwin BT634 $19.50 + $7.95 postage. Jag prestige spares (ebay)
Brintech $58.94 + $8.60 postage ,brintech_customs (ebay)
HiFi HO-7801 (can't find a listing today)
Those are your choices, I can order it and have it here if you want.(since you don't do ebay) Just let me know which one you want
I have just ordered the Fram one for mine from Presto Paige Classic, hoping it will arrive tomorrow to do my oil change.
Old Jun 9, 2015 | 07:20 AM
Doug's Avatar
The Jaguar EBC9658 works perfectly well.
AC Delco PF964
Fram PH2995 or 2931
Bosch 72147 or 72175
Mann W93013
Baldwin BT292
NAPA 1231
Old Jun 9, 2015 | 07:58 AM
Coop613's Avatar
AC Delco PF964
Fram PH2995 or 2931
Mann W93013
Baldwin BT292
NAPA 1231
Thank you!
Old Jun 9, 2015 | 11:07 AM
ptjs1's Avatar
I'm afraid your Jaguar dealer has completely misled you and presumably doesn't know much about older models.
The filter has always been available from Jaguar, EBC9658 as mentioned. See the Jaguar website here:
Oil Filter-Relief Flow Oil Cooling-5.3 Litre - Parts For XJS from (V)139052 to (V)179736 | Jaguar Heritage Parts UK
Good luck
Paul
Old Jun 9, 2015 | 11:40 AM
Doug's Avatar
Well......The dealer wasn't wrong, technically
The oil filters originally used on the V12s are, indeed, no longer available. The EBC9658 is a replacement that replaces two or three older filters/part numbers.
If the dealer indicated that Jaguar no longer supplies a suitable filter.....which appears to be the case with the dealer in question.....that is obviously wrong.
Old Jun 9, 2015 | 12:26 PM
Vee's Avatar
Vee
I was made to believe that the OEM Manufacturer is Mann (W930-13). I have been using Mann, and occasionally Mahle (OC238).
You can do some research and your head will explode from all the information available. Be careful what you wish for.
Old Jun 10, 2015 | 02:57 PM
Coop613's Avatar
All the dealer said was that they are discontinued and didn't even mention another filter that fits it (and the guy was rude). Once I saw your post and called back with the EBC9658 part number I had no problem getting one.. so thank you!!!
Old Jun 14, 2015 | 09:34 PM
Eaa's Avatar
Eaa
I used Wix 51231, $12.50 and in stock at Oreilly Auto.
aholbro1
Dec 29, 2024 06:46 PM
Scarecrow
Mar 28, 2016 03:17 AM
teacoff
Sep 10, 2015 08:25 AM
jaggermang
Sep 8, 2015 07:07 PM
pnwrs2000
Sep 3, 2015 11:55 AM
